Back to Article
10 of 21
9 The long black wire is the tachometer feed and needs to pass through the firewall. The instructions suggest the accelerator-pedal-rod seal, but we found enough gap in the A/C-hose grommet to pass the wire through at this point. You can also drill a small, discreet hole to pass the wire through.
