Steve Baur
March 30, 2011
Contributers: Marc Christ Photos By: Marc Christ, Courtesy Of TCI Automotive
If you've been following our NMRA True Street project Repeat Offender, then you know our '85 notchback is packing a serious FRPP 427ci engine, and we fully expect it to run 9s when we're done. If you haven't caught any of the recent installments, then what you need to know is that we went with a rather unconventional transmission choice-one that you may find of particular interest if your ride is street driven and making a lot of horsepower.
One thing that you have to realize when competing in the True Street class is that the track surface gets very slippery, especially during the events where you have 60 or more cars entered. We have seen how the large majority of entrants with the same (or similar) wheelbase tear up the track surface with their street tires. All three runs are back-to-back, usually with no track prep in between, so if you have a high-powered Pony, you have to do your best to get the power down.
As much as Repeat Offender's owner is a die-hard stick guy, he realized an automatic transmission was the way to go. In most cases, an auto will hit the tires much more softly (especially compared to a street clutch), which is essential, especially when you run a drag radial. That being said, there are plenty of automatic options out there including the C4 and Powerglide transmissions, however, we wanted an overdrive transmission since Repeat Offender will be a registered and insured street car.
There are a number of companies that produce fortified AOD units, and we've also seen a number of 5R55S five-speed automatic retrofits come to market as well. We liked the idea of the extra gear, but at the time of our decision, none of these had the tuning in the transmission controller to go with it. What we did find was the new 6X six-speed automatic transmission from TCI. TCI already had a number of vehicles up and running with its TCU transmission controller, so for a change, we wouldn't be the guinea pigs.
The TCI 6X is based off of the GM 4L80E, and yes, we know there will be purists who put up a fight, but Ford guys have been using the Powerglide for years without much fuss. Besides, if the GM guys want a good rearend, they have to use a Ford 9-inch, right? That being said, the TCI 6X is also not as budget friendly as many Mustang enthusiasts are used to, but we felt the need to try it out for you, in order to give you the lowdown.
The main feature of the 6X that attracted us was its six-speed capability. Though GM's 4L80E is merely a four-speed, the engineers at TCI have developed a new valvebody with an extra shift solenoid to work in conjunction with a transmission control unit (TCU) to provide six forward gears-only one of which is an overdrive. The main benefit is the close ratio forward gears (2.97, 2.23, 1.57, 1.18, 1.00, and 0.75), which will keep the engine in its peak power band for optimal e.t. You may recall a production car with similarly functioning automatic and manual transmissions-the '11 Mustang GT.
Another outstanding feature is its power-handling capability. "The baseline version will handle up to 850 hp, but we can custom-build one to handle 1,200 to 1,300 hp," says Scott Miller of TCI. The entry-level version was enough for us, but if you're building a twin-turbo street/strip monster, then TCI can build a 6X just for you. Other than heat-treated, high-strength components internally, combining the 6X with a TCI StreetFighter torque converter ensures its 850hp capability. "The billet front cover of the StreetFighter allows us to run a 2-inch-wide clutch versus a 3/4-inch-wide clutch on a standard converter-necessary for high horsepower applications," added Miller.
