Kristian Grimsland
Associate Editor, Muscle Mustangs & Fast Fords
March 1, 2013
Innovative Blower
ProCharger is proud to release the industry's first programmable ratio supercharger for '11-'13 5.0L Mustangs. Its new i-1 supercharger, features an intelligent control system and optional touch screen display, allowing drivers to switch between three factory-supplied performance modes, as well as a custom mode. Programmable boost is delivered by a highly durable variable ratio transmission design, with a rugged, dry hybrid drive. If you've been looking for versatility in a blower, than look no further. Look for a full story in the April issue.
Chassis Stiffening
Steeda Autosports has released its rear seat chassis X-brace for '10-'13 Mustangs. Designed from 4130 chrome-moly, it helps to strengthen handling, and eliminate squeaks and rattles. The X-brace installs in the chassis area between the rear wheelwells behind the rear seats. With the X-brace installed, it effectively couples the rear structure together to increase chassis rigidity. Retail price is $299.95.
It's in the Details
If you're a detail perfectionist when it comes to keeping your Mustang or Ford clean, than you've probably used Meguiar's detailing products. Making detailing even easier, Meguiar's has released its DA Powersystem. Attach the Meguiar's PowerSystem to a regular 3/8-inch corded power drill, with a recommended speed range of 1,200 to 2,500 rpm, and begin polishing. The Powersystem is available at most major auto retailers and retails for about $59.95.
Stiff Shifting
Quit the daily grind—the daily shift grind, that is. Your '11-'13 Mustang's stock transmission shifter bushing is made of soft rubber and can wear out overtime, causing sloppy shifting. Energy Suspension offers a firmer, polyurethane upgrade that will offer greater, consistent shifting and is fast and easy to install. Don't miss another shift!
