May 22, 2014
New Finish
Mickey Thompson's Street Comp SC-5 wheel design is now available in a variety of finishes. The SC-5's original finish is gloss black with a machined lip, and jumping into the lineup are flat black (all flat black) and hypersilver (machined lip). Mickey Thompson says the SC-5 is the perfect complement to the company's Street Comp UHP tire, and it's available in 12 popular sizes, covering 17-, 18-, and 20-in diameters. The SC-5 wheel design is the foundation for Mickey Thompson's Enhanced Stance System. Info: (330) 928-9092;
S197 Grip
Maximum Motorsports is a big player in the handling game. Its line of Grip Box packages are well-established, and now the company has a Grip Box for '05-'14 Mustangs. Maximum's new Road & Track Grip Box is designed to combine comfortable ride quality with grip capable of cornering at a continuous 1.2g on street tires. Matched components include Koni adjustable struts and shocks, custom springs, a front sway bar, caster/camber plates, an adjustable Panhard bar, rear lower control arms, shorter bump stops, and everything needed to install the system. Everything is designed for easy assembly with common tools. Maximum also offers these parts separately. Info: (805) 544-8748;
Fresh Upgrade
Performance Automatic has these performance rebuild kits for the '05-'10 5R55 and '11-'14 6R80 Mustang automatic transmissions. Performance Automatic's “Max Performance” kit is ideal for freshening your existing transmission or upgrading it to the next level of performance. Both kits come complete with all seals, gaskets and Raybestos Performance clutches you need to bring your Mustang's transmission back to life. The PAKT68700 is the kit you need for your '11-'14 Mustang GT and PA27401 for your '05-'10. Info: (240) 439-4650;
Duck…Duck…Goose It
If you want to make your '05-'09 Mustang look like it's speeding down the road even when sitting still, check out the MMD Duck Tail Spoiler from The spoiler is made from durable, lightweight ABS plastic, and is a direct replacement for the factory spoiler. The spoiler is available in all factory colors, which makes it ready to bolt on to your Mustang right out of the box. Info: (866) 727-1266;
Pen Pals
If you drive your Mustang on a regular basis, paint chips become a part of life. To take care of those blemishes, AutomotiveTouchup has released its Touchup Paint Pen series. Clean, convenient and cost-effective, the touchup pens make DIY automotive touchup work quick and easy. AutomotiveTouchup offers a Primer Paint Pen, a Basecoat Paint Pen, and a High Gloss Clearcoat pen. This process is designed to more closely resemble the factory paint than what simple touch-up paint can do. Info: (888) 710-5192;
