Kristian Grimsland
Associate Editor, Muscle Mustangs & Fast Fords
February 13, 2014
Boost It Up
Whether you have a factory '05-'10 Roush Mustang or Mustang GT with a Roush blower added, you will now be able to take advantage of the latest TVS supercharging technology. VMP Superchargers has just released its new 1.9L TVS supercharger. According to VMP, its all-new supercharger replaces the factory M90 piece and can safely gain over 100 rwhp on the stock engine. Pricing starts at $3,399.
WEB Phone 321/206-9369
Cooling Effect
Keep your '10-'14 Mustang cool with Blow-By Racing's new 160-degree thermostat. Designed to offer more precise metering of coolant throughout your engine, its new thermostat offers up to a 20-degree improvement in engine coolant temperatures. Purchase one today directly online at the company website $34.95.
WEB Phone 561/417-5555
Sport Seats
Do you want to give your Mustang's interior a new look? If so, look no further. TMI Products has just released its newest addition to its sport seat lineup—the Sport R500. Designed for '84-'09 Mustangs, its new seat takes styling cues from the '13 GT500, but has been redesigned all its own. Utilize your factory seat frames and TMI's new seat foam, and combine it with its all-new Sport R500 upholstery for a whole new look. Contact TMI products for its extensive list of factory and custom colors.
WEB Phone 951/272-1996
New Looks
SilverHorse Racing is proud to introduce its newest Tru-Billet replacement window switch plates for '10-'14 Mustangs. Plates are available in a two-tone silver-anodized or triple-chrome-plated finish. Each piece is machined and finished directly in the USA from solid blocks of aircraft alloy on SHR's in-house, modern CNC machines for a perfect fit. Install time is only a few minutes using factory-mounting tabs, and the cost is $189.99.
WEB Phone 321/722-2813
Premium Synthetic
Premium synthetic lubricant manufacturer Royal Purple has announced the addition of its new HMX, high-mileage synthetic motor oil. Designed for engines with more than 75,000 miles, HMX is chemically enhanced to revitalize hardened seals, reducing oil consumption common in high-mileage engines. In addition, HMX is fortified with stout detergents to remove engine buildup and deposits, maintain cleanliness, and promote engine longevity.
WEB Phone 888/382-6300
Taillight Fashion is proud to introduce Raxiom's Generation 5-style taillights for '05-'09 Mustangs. These lights allow you to transform your Stang's rearend to look identical to '13-to-present Mustangs. Equipped with LED lighting and inset taillight fixtures, these lights are sure to refresh your Stang's looks.
WEB Phone 866/727-1266
Jon Kaase Racing Engines has recently released its new one-piece, shaft-mounted roller rockers for its P-51 big-block Ford engines. Its new aluminum rockers add stability, along with strength and accuracy. Each rocker body is 1.650 inch in length and is a twin needle-bearing design. According to JKRE, this design helps in lubrication. Alternative rocker ratios are available from 1.73:1 to 1.80:1
WEB Phone 770/307-0241
Control Issues
Maximum Motorsports' new drag-race rear lower control arms deliver both adjustability and durability demanded by Mustang drag racers and serious street enthusiasts. Engineered for high-powered '79-'04 Mustangs producing up to 1,000 lb-ft of torque, its latest design allows for ride-height and spring-rate tuning. These control arms accept standard Mustang springs. Recommended accessories include Maximum's 2.50-inch rear-spring adapter, which enables fine-tuning of standard springs in 25-lb/in increments.
WEB Phone 800/839-0928
