February 3, 2014
Big Bore
Thanks to Ford Racing's new Big-Bore blocks, the last thing you'll be is bored. With a 302 Boss, a 9.2-inch-deck 351 Boss, and a 9.5-inch 351 Boss Big Bore block, your Mustang won't be lacking cubic inches. With the 9.5-inch 351 Boss block, 460 ci are possible, which is the basis for Ford Racing's new 460 small-block crate engine. The 302 Boss version is capable of stretching out to 363 ci. Cast from diesel-grade iron with Siamese bores, thick cylinder walls and decks, these big-bore Boss blocks are said to be far superior to any Ford production block.
Proper Drag
To get the most out of your Mustang the next time you take it to the track, you'll need a proper drag setup. Latemodel Restoration has just what you need—these SVE Drag wheels for ‘94-'14 Mustangs. They will help you arrive at the best performance possible. Featuring a one-piece alloy aluminum construction, and available in 15- and 17-inch sizes, the wheels come in black, dark stainless, and of course, chrome. They don't require special lug nuts or hub rings, which is definitely a plus.
Power Swap
If you're contemplating a Coyote swap into your ‘96-'10 Mustang, Power by the Hour Performance has this kit designed to make it a more simple transition. Power by the Hour's kit allows the use of all accessories, keep everything in the factory location, and retain factory A/C lines, power-steering lines, and alternator harness. Some modifications may be needed depending on your year Mustang, but Power by the Hour's kit has most of the work done for you, and it only costs $549.
Dressing Up
If showing your Mustang is the game, check out American Car Craft's engine dress-up products. Designed for '11-'13 Mustang GTs, American Car Craft's lineup has everything covered in the way of bringing shine to your Mustang's engine compartment. From polished caps to header plates, and everything in between, American Car Craft can supply you with whatever product you need to bring home a trophy at the next show.
'Back It Up
With the '11-'14 Mustang GT, probably the easiest bolt-on you can add is an after-cat exhaust. You can swap out the old, and add the new in roughly 45 minutes. MBRP is hoping you choose the Street or Race version of its after-cat exhaust. Both are designed as 100-percent bolt-in parts. A one-piece extension and over-axle pipes allow for easy installation. MBRP states it dyno-tunes these after-cat exhausts for maximum performance, and its kits produce as much as twice the flow rate over stock.
We recently had an up close and personal look at Centerforce's DYAD DS multi-disc clutch for a project car, and was blown away. Now this clutch is available for '09-'13 Shelby GT500s. The clutch package includes a pressure plate, disc set, floater, low-inertia steel flywheel, alignment tool, hydraulic bearing, and hardware. This multi-disc system replaces the factory clutch with a higher holding capacity system designed for smooth engagement and light pedal effort. The clutch is said to corral up to 1,300 lb-ft of torque at the flywheel, and comes pre-assembled for your convenience.
Max Boost
Perhaps your '11-'14 Shelby GT500 needs a little help in the fuel delivery department, what are your options? JMS Chip and Performance would like for you to check out its PowerMax FuelMax fuel pump voltage booster. The system is designed for plug-and-play option, with as much as an 80-percent increase in fuel delivery, according to JMS. The booster is designed to increase regulated voltage without increased noise with an output rating of 21 amps at 18 or 21 volts. The product will operate with an input voltage between 9.5 and 19 volts DC with the lowest voltage drop at 0.05 volts. Output voltage is controlled by a simple knob that adjusts up to 21 volts. You can also control the ramp-in and ramp-out rate to correct or eliminate fuel pressure spikes to maximize performance and fuel delivery.
StopTech It
With all the power available at the click of a mouse, your Mustang needs braking power, as well. Summit Racing now has these StopTech drilled or slotted rotors in Mustang applications. StopTech rotors are fully machined, inspected, and mill- balanced to reduce vibration and increase resistance to heat. Most rotors have StopTech's corrosion-resistant E-coat finish on both sides of the hat, inside the cooling vanes, and on the outside edge. This finish reduces the accumulation of rust that can cause runout issues, hamper the brake's performance, and accelerate brake-pad wear.
Lethal Pipes
Just like in the old Fox days, we still love a good off-road pipe. Lethal Performance has this H-pipe and X-shape crossover pipe designed for '11-'14 Mustang GTs and Boss 302s. The 3-inch, mandrel-bent pipes promise uncompromised flow with increased performance to boot. Both the H- and X- are $299.99—a veritable bargain these days. Better yet, both deliver the sound we want from our Mustangs. Both are easily installed, and up to 14 rwhp is possible after less than an hour's install work.
Stainless Silicone
At some point in your Mustang life, you're going to need an assortment of silicone hoses, especially if engine swaps are in your future. Burns Stainless has silicone hoses, couplers, reducers, and the like, to get fluids, or air, where they need to be. Burns also offers straight and 90-degree silicone hose reinforced with four plies of quality polyester fabric, five layers of silicone, and coated with a silicone elastomer. All that means is that the hoses are designed to make it through whatever you can throw at them, but still remain flexible.
Click Click
If your '05-'14 Mustang needs adjustable dampers, check out Strange Engineering's externally adjustable shocks and struts. These gas-charged shocks and struts have 10 performance settings to help you take your Mustang from the street to the strip in just a few clicks. Constructed with an external adjustment knob and durable steel body, these Strange dampers are affordably priced, and are a direct bolt-in to help you lower your Mustang's elapsed times.
Phantom Fuel
One thing you don't want is inadequate fuel flow. With Aeromotive's Phantom Fuel System, inadequate fuel flow is a thing of the past. The Phantom system is a complete kit designed for almost any fuel tank, and power level. The Phantom 200 is the baseline kit, designed for 550hp EFI combinations, or 750 horsepower in carbureted applications. The Phantom 340 is based on the Stealth 340 pump, and is capable of supporting much more.
