July 1, 2004
Mufflers on the CheapI'm looking for low-buck performance mods for my '02 GT convertible, mainly because my wife doesn't think Mustang parts are as important as groceries. I have also recently discovered the joys of shopping on eBay. I found an '01 Cobra stock exhaust system for less than $100.
Wouldn't the Cobra mufflers be an improvement for my '02 GT? Could you recommend an aftermarket muffler that improves performance but is also reasonably quiet?Mark BartonLucedale, MS
A used aftermarket exhaust system would be a better bet than the Cobra mufflers. It's never been tested, but I would guess the Cobra mufflers wouldn't really allow the engine to make any more power than what's on the car now.
Recommending an aftermarket after-cat (behind the catalytic converters) exhaust system is tough to do since the systems sound different from one another. It's a subjective issue that's best decided by hearing various systems on Mustangs so-equipped. All of them should help make a measurable difference in power output (usually in the 10-15hp range), and most fit pretty well and can be considered a bolt-on upgrade. You have to decide which one you like based on sound. There are probably a dozen or more manufacturers that make systems for late-model Mustangs. Examples include Bassani, Borla, DynoMax, Flowmaster, Hooker, JBA, MagnaFlow, SLP, Spintech, and certainly others.
Check company Web sites and shop around (eBay is a good source for used parts as are many Mustang Web sites such as www.corral.net and www.stangnet.com.
Also consider other low-buck options such as cold-air kits, a set of 3.55 or 3.73 rearend gears, and that ultimate bang-for-the-buck standby: nitrous. Both NOS and Edelbrock offer good-quality nitrous systems for your car that, when tuned right, work quite well in safely offering 100 or more horsepower.
Gear Ratio RationaleIn your Jan. '04 issue, a reader asked about the gear ratio in his '97 GT. You stated you didn't know of any optional ratio on '96-'03 two-valve engines. My two-valve '96 GT came with an "optional ratio axle," as clearly marked on the window sticker. This engine turns about 200 rpm faster than my '89 LX 5.0 (which I still have and can make direct comparisons) at around 65 mph. My assumption had been the '89 had a 3.08, so the '96 must have a 3.27. Now I'm wondering if my '96's option is the 3.08, which would make the LX ratio a 2.73. Maybe I was able to answer the question if there was an optional ratio.John McIlnayDunlap, IL
The window sticker you sent clearly shows the optional gear ratio listed in the fourth line from the bottom under "optional equipment" on the right side of the sticker. Thanks to your input, I realized I wasn't fully informed about this subject when I replied to Scott Sauter in my January column. Turns out there was an optional ratio for all '94-'98 5.0 and 4.6 GTs. According to the Mustang Red Book by Peter Sessler, the standard ratio for your car was 2.73 and the optional ratio was 3.27.
You didn't say whether your Fox-body is a five-speed or an automatic (which could make a difference in axle ratios and how the car is equipped), but it would seem your original assumptions are correct. If the '96 has the 3.27 and the '89's engine turns a little slower at speed, then it likely has a 3.08. If it were a 2.73, the difference between the two cars would be more than 200 rpm at highway speeds; it would be in the 300-400-rpm range.
When I said I had never heard of an optional ratio, I was speaking of the '99 and newer cars; that is, square-edge Mustangs. Including the earlier round-body cars was incorrect. But for the '99-'04s, I'm certain all of them have a 3.27 ratio. That includes V-6, GT, and Cobra models, both automatics and five-speeds. Starting with the '99s, optional axle ratios were dropped and the 3.27 became standard fare in Mustangs. The only exceptions, of course, are '03-'04 Mach 1s and Cobras, which are factory-equipped with 3.55s.
Horse with a Bird's TailI have an '87 Mustang GT and want to add rear disc brakes. I have a complete 8.8-inch rearend out of an '88 Thunderbird Turbo coupe I parted out, plus the proportioning valve, master cylinder, and booster. On preliminary investigation, it appears to be almost a bolt-in. Do you have any advice or info for this swap? Can I use the T-bird proportioning valve, master cylinder, and booster, or should I go with aftermarket pieces?Paul PrinceVia the Internet
While the T-bird rearend is 1.5 inches wider, it should be a direct bolt-in. The folks at Windsor-Fox have an '88 Thunderbird Turbo coupe and an '84 Mustang GT. We asked them to measure the 8.8s in both cars. The Mustang axle is 5911/44 inches wide and the T-Bird 8.8 is 6031/44 inches wide-an inch wider on each side.
Of course, since the T-bird axle is wider, your existing wheels will stick out that much more. You could run an aftermarket wheel with a different offset to compensate for the wider axle. You'll be able to better determine your exact needs once the T-bird rearend is in the car. One option is to find a set of '93 Cobra wheels. These 17x7.5-inch wheels are four-lug and would have the proper offset for the T-bird axle.
Concerning the proportioning valve, master cylinder, and booster, I don't see why these pieces wouldn't work in your Fox T-bird. You might be able to also swap in the axle and run the rest of the brake system as is. If I hear otherwise, I'll certainly run the updated information in this column.
Send your late-model questions or comments to: Late-Model Corral, c/o Mustang Monthly, 3816 Industry Blvd., Lakeland, FL 33811. Please include your VIN and/or data plate information, daytime phone number, and e-mail address. You may also reach us via e-mail at: latemod.corral@primedia.com.
YO Club Sweepstakes Rules1. No Purchase Necessary. A Purchase Does Not Improve Your Chances Of Winning. Void Where Prohibited.
2. Sweepstakes begins at 12:00:01 A.M. EST on July 1, 2003 and ends at 11:59:59 P.M. on June 24, 2004.
3. Sweepstakes will be open to males/females, ages 16 to 25, with a valid driver's license as of July 1, 2003 who are legal residents of the fifty (50) United States and the District of Columbia. Employees of Mustang Monthly and Mustang & Fords Magazines ("Sponsors"), CJ Pony Parts, Mobile Mustang, Competition Cams, Tony Branda Performance, National Parts Depot, Canadian Mustang, Mustangs Plus, Carlisle Events, Texas Mustang, California Mustang, Rod & Custom Motorsports, and Classic Auto Air (all collectively "Prize Suppliers"), their respective parents, subsidiaries, affiliates, advertising and promotion agencies and their family members and/or those living in the same household are not eligible to enter.
4. Enter by filling out an official entry form available within the magazine issue, or at www.mustangmonthly.com and www.mustangandfords.com, or by sending your name, address, date of birth, phone number, year/make/model of car, color of car, engine type, length of ownership, and primary use of car on a 3" X 5" card. Send your entry, along with a photo of your Ford vehicle, to YO Club Membership, Attn: Young Owners Club Registration, 3816 Industry Boulevard, Lakeland, FL 33811, or email the required information to yo.club@primedia.com. Entries must be received by dates listed in the Monthly Deadline, Drawing and Prize Schedule below (the "Schedule"). Multiple entries are not permitted. One entrant per entry. Sponsors and Prize Suppliers shall not be responsible for lost, late, mutilated or misdirected entries. Entry forms or requests that are printed by machine, mechanically reproduced, tampered with, illegible or incomplete are not eligible.
5. The sweepstakes will take place under the supervision of the Sponsors. Participants agree to be bound by these rules and the decision of the judges, whose decisions are final. The winners will be notified by mail or email by dates listed in the Schedule below for each drawing. To obtain a list of winners, send a self-addressed, stamped envelope, after August 15, 2004 to: Young Owners Club Registration, 3816 Industry Boulevard, Lakeland, FL 33566.
6. The Sponsors will randomly draw one winner each month from each drawing as indicated in the Schedule below. Each entry received is eligible for all subsequent drawings which have not yet taken place at time of receipt of entry. Each month's winner will be awarded the prize as indicated in the Schedule below. Odds of winning each drawing will be determined by the number of eligible entries received. Sponsors and Prize Suppliers make no warranties with regard to the prizes. Prizes are not transferable. No substitutions of prize allowed by winner, but Sponsors and Prize Suppliers reserve the right to substitute a prize of equal or greater value. Prizes are not redeemable by winner for cash value.
7. Total approximate value of all prizes is $4,800.00.
8. All entries and requests become the property of the Sponsors and will not be acknowledged or returned. The Sponsors will have the right to photograph the winner. Entry constitutes permission to use the winner's name, picture, likeness and city and state of residence for purposes of trade, publicity or promotion for no additional compensation except where prohibited by law.
9. All entrants release the Sponsors and Prize Suppliers, their affiliates, parents, subsidiaries, directors, officers, employees, and agents, and all others associated with the development and execution of this from any and all liability from injury, loss or damage of any kind resulting from participation in this promotion or acceptance or use of any prize.
10. Prizes must be claimed by the dates listed below in the schedule below or a new winner will be chosen at the discretion of the Sponsors. At time prize is claimed, winner may be sent an affidavit of eligibility/publicity/liability release, which must be returned within the time frame specified before the prize, is awarded. Failure to execute and return any requested document within the time frame specified or return of notification or prize as undeliverable may result in forfeiture of the prize. An alternate potential winner may be selected at the sole discretion of Sponsors. All reasonable effort will be made to contact the winners. All taxes on all prizes are the responsibility of the winners.
