Dave Stribling
April 13, 2016
Caster/Camber Tool Explained
In the January 2016 “Beyond the Basics” column on page 82 in the letter titled “Bumpsteer Bugs,” there is a photo of an alignment tool being used. I would appreciate it if you could share some info about that tool, such as the maker and where to purchase it.
Neil Oliver
Via the Internet
This is a hub-style caster/camber alignment tool I picked up from Speedway Motors (www.speedwaymotors.com, PN 91082610). It is an inexpensive way to set the caster and camber on your car. I use it to get the setting close before I take the car to have it aligned. It works great.
To check the camber, you need the car level, the suspension at the static ride height, and the wheels pointing straight ahead. (I’m cheating in the photo and using my lift to get the shot.) The gauge has a couple magnetic mounts that attach to the hub, and you usually have to pull the dust cap. There is a small bubble level in the gauge and a dial with eight segments representing one-eighth degree each. Once the wheel is pointing straight, zero up the gauge, and mount it vertically to the hub (you can use another bubble gauge to check the vertical). Rotate the dial until the bubble centers and count the segments on the dial. Clockwise is positive camber; counterclockwise is negative camber. If you went four segments counterclockwise, you are at a one-half a degree negative camber.
The caster measurement is determined by checking how much rotation you have between 20 degrees turned in (about one revolution of the steering wheel in most cars) and 20 degrees out. After leveling and zeroing the gauge 20 degrees in, move the wheels back to straight, and move them out 20 degrees. Set the gauge back to vertical and see how many revolutions it takes to center the bubble, then you multiply this by 1.5 to get your caster setting. For instance, if it took 1 1/2 revolutions clockwise, it would be 1.5 x 1.5 = 2.25 degrees of positive caster. There are fancier tools that do the same thing, but this inexpensive little tool is a great addition to your toolbox.
Fuel Level Sender Differences
Can I run a ’69 Mustang fuel sender in my ’70 Mustang? The part’s place says these parts are different, but I believe they are the same. I have a ’69 sender just sitting around that I could use in my ’70 Mustang, if they are indeed the same.
Marco (last name withheld)
Via the Internet
The sending units for ’69 and ’70 are different. The gas tank in ’69 has a 20-gallon capacity, while the ’70 holds 22 gallons. The ’69 is deeper and taller than the ’65 to ’68 tank, and the ’70 is deeper and taller than the ’69. Because the tank is deeper, the arm on a ’70 sending unit is about 6 1/8-inches long, while the ’69 sending unit is just under 6-inches long at 5 7/8 (ish). This means if you try to run the ’69 sender in your ’70, the sending unit it’s going to bottom out too soon, and you will think you are out of gas. Better to just go ahead and buy a new sending unit and save the ’69 sending unit for your next project.
Compare the ’69 and ’70 fuel sending units. Note the slightly longer arm on the ’70 unit on top. Original sending units come with a Cougar part number. The ’69 is PN C9WF-9275-A and the ’70 is PN D0WF-9275-A.
