Mustang Monthly
Getting It Right: 1965 Mustang Door Gaps
Getting door gaps right starts with solid door hinges
After decades of service, the typical classic Mustang door hinge has no doubt seen better days. Sloppy clearances, worn hinge pins, broken or missing door check springs, and more can all lead to unsightly door gap changes, and in extreme cases, even sheetmetal damage. If you’re in the middle of bodywork or sheetmetal repairs, it is imperative that you are working with solid door hinges, or all of your bodywork and panel alignment will be for naught.
While we’ve covered rebuilding the actual hinge in the past (you can brush up on the steps at: mustang-360.com/how-to/paint-body/127-0402-door-hinges-rebuild), you of course have the option of purchasing reproduction hinges. Repro hinges are a good option if your hinges show signs of accident damage or are so far worn that they’re not rebuildable. What we’ll be focusing on for this project is using solid hinges to perform door to quarter-panel and door to rocker alignment. So follow along with your rebuilt or repro hinges, and we’ll have your doors aligned and ready to finish your bodywork in no time.
Photography by Mark Houlahan
