September 1, 1998
P62673_image_largeP63050_image_large
Take extra care when dismantling your seats. Clint Sharp of Ambrose Custom Interiors carefully pops the seatback covers in this case because they were in good condition and reusable.
P63051_image_large
Clint takes a large screwdriver and works the seatback pivot off the seat bottom as shown. Our advice? Take extra care and bear against the seat frame with the screwdriver.
P63052_image_large
Not enough restorers pay attention to seat tracks. For smooth operation, clean and lubricate the seat tracks while they’re apart. We suggest graphite grease on the tracks, which is a dry grease.
P63053_image_large
Seat foam should always be replaced. New foam feels good and provides firm support underneath new upholstery.
P63054_image_large
The only original pieces in your seat should be the frames. Ambrose Custom Interiors fits Bill’s buckets with new burlap, which provides support and structure.
P63055_image_large
New seat upholstery from Texas Mustang Parts is laid out in the sun to soften it up and make it workable. Always do this before you begin installation.
P63093_image_large
The seat foam gets an application of 3M Trim Adhesive, which enables it to stick to the burlap securely.
P63097_image_large
Whenever possible, use the original wire listing to retain the upholstery. If you have to replace the old listing, use a thin-gauge coat hanger wire. Carefully feed the listing into the sleeves as shown.
P63098_image_large
Clint fits the upholstery in place, then begins hog-ringing the upholstery.
P63106_image_large
He suggests hooking the hog ring around the listing top first, as shown, then giving it hell. This ensures a tight fit.
P63107_image_large
Cradle the foam as shown, then pull the upholstery over and aim for a snug fit.
P63108_image_large
After you’ve hog-ringed everything in place, find the seatback panel clip attachment holes, punch same, and pop the cover in place.
P63109_image_large
As with the seatback cover, punch the appropriate holes and install your Texas Mustang hardware.
P63110_image_large
Reinstall the seat back as shown, taking extra care not to puncture the new upholstery.
P63111_image_large
Make your efforts shine with new trim pieces from Texas Mustang Parts. Clint finishes out his work with new anodized aluminum.
P63112_image_large
Our completed bucket seat is ready for action.
P63113_image_large
Bill Kepp puts down the carpet underlayment from Texas Mustang Parts.
P63114_image_large
We’re not completely certain which side faces down, but we put ours down so it conformed to the shape of the floorpan. For some underlayment pieces, it’s common sense.
P63115_image_large
If you have a manual transmission, don’t forget to install the boot before the carpet goes in.
P63133_image_large
Carpet installation can be challenging. Bill lays the carpet in...
P63134_image_large
...pushing the molded segments into the corners.
P63135_image_large
Then he pulls the manual shifter boot up through the carpet.
P63136_image_large
We installed our Texas Mustang dashpad with ease.
P63137_image_large
Simply seat the pad, then install the tinnerman’s nuts from behind.
P63138_image_large
Our project Mustang doesn’t have the windshield yet.
P63139_image_large
Before you install the door panels, don’t forget the watershields to keep unnecessary moisture off your door panels. Use a pliable water sealer between the watershield and the door.
P63140_image_large
The door panels from Texas Mustang Parts installed with ease because they arrived with new retainer clips. These clips slip into the door panel toward the front of the vehicle. Seat the clip and give the panel a solid whack with the heel of your palm.
P63141_image_large
Before you can install the armrest, you must carefully cut out the soft impressions midpanel. Gently find them, then cut the panel out in this area as shown.
P63142_image_large
Find the armrest screw tinnerman’s clip in the door and start the screw.
P63143_image_large
Finish up by installing the door handles and lock button.
P63144_image_large
Check this out. Did you know ’65–’66 Mustangs can be equipped with an overhead courtesy lamp? The provisions are there for one, so we took advantage. Simply route the wire to the left-hand side of the car, then aft, then down to the “C” pillar area. You can tie the lead into the underdash courtesy lamps.
P63145_image_large
Before the headliner goes in, the insulation must be installed. We suggest the foil-backed padding shown here. It isolates summertime heat and wintertime cold, plus it isolates sound. Glue it in with 3M Trim Adhesive.
P63147_image_large
Feed the overhead wires into the headliner as shown. Do not confuse the appropriate wire positions.
P63148_image_large
Support wires are installed first and then pressed against the insulation.
P63149_image_large
Once all of the wires are positioned, work fore and aft first, pulling the headliner firm. Apply 3M Trim Adhesive along the edges at the backlight and C pillars, then on the headliner at the attachment points. Allow the adhesive to dry to a tacky state, then pull and attach the headliner. Hold the headliner with windlace pieces cut in small segments. When the rear is secured, pull the headliner firmly toward the front of the body and attach it at the windshield. Finally, pull the sides firm and do the same thing around the door openings.
P63150_image_large
Install the dome light lens and bezel. This is a nice touch for a ’65–’66 Mustang because it provides much needed light.
P63151_image_large
Because Bill is building a restomod, he opted for the Haneline instrument panel for Falcons and Mustangs. We showed you how to install this attractive cluster in the June ’98 issue (“Panel Discussion,” page 62). For more details, contact Haneline Products.
P63152_image_large
A good-looking instrument panel wouldn’t be worth much without a Grant steering wheel to seal the deal. Our once humble six-cylinder coupe is taking shape.
P63154_image_large
Bill readies the interior quarter trim panels.
P63155_image_large
The panels have been stripped and painted in the appropriate satin black. Insulation is installed using 3M Trim Adhesive for noise reduction and comfort.
P63156_image_large
Windlace comes next. Don’t forget to install the window crank using an Allen wrench.
P63165_image_large
Carpeting often has to be trimmed carefully to accommodate the sill plate and kick panel.
P63166_image_large
Finally, we’re ready for the front and rear seats. When you install the bucket seats, don’t forget the floorpan plugs underneath.
P63167_image_large
The rear seatback hangs on brackets and is easy to install. The seat bottom just pops right in.
P63168_image_large
Depending upon the condition of your glove compartment door, we suggest the installation of a new one from Texas Mustang Parts. For around $100, it’s a good investment.
P63169_image_large
Bill is on the way to a completed restomod—a Mustang that will be a thrill to drive.
Recently, Bill Kepp took his 1965 Mustang from zero to hero with do-it-yourself budget paint and bodywork. Kepp was deeply moved by the results he achieved with help from Covina Auto Body and PPG Finishes. The result is a striking green metallic clearcoat ’66 Mustang coupe for less money—a good thing because it managed to free up cash Bill could spend elsewhere on his coupe.
With a painted pony in tow, Bill is ready to tackle vehicle assembly. We called Texas Mustang Parts and spoke with Jerry Weaver, who got us dialed in to a complete black vinyl standard interior for Bill’s ride. With help from Jerry’s assistant, Karol Kuehl, we got outstanding service on our interior project. Texas Mustang Parts was eager to help, coming up with parts and pieces we hadn’t thought of. It was like Christmas morning when the packages arrived from Waco, Texas.
To understand Bill’s excitement, you have to understand the history of the car—and Bill. This is Bill’s first Mustang ever. It was a $400 six-cylinder with a horrible body. In it, Bill saw promise where others saw scrap. Over a few weeks, it was transformed from beater to beauty—clad in a glistening green clearcoat finish and ready for assembly. We’re eager to get started, so follow along with us as we present you with the basics of what it takes to reform a Mustang’s interior into an environment you’ll be proud of.
Our objective isn’t to show you in great detail how to restore an interior, but basically what you can expect when it’s time to handle yours. We’re going to arm you with useful tips designed to help you achieve your dreams, just like Bill is achieving his.
Seats
We looked to the very best for guidance on our seat upholstery. Texas Mustang Parts stocks Distinctive Industries seat upholstery. We were very pleased with the quality. Then we looked to Mike Ambrose of Ambrose Custom Interiors for outstanding results. Mike didn’t disappoint us.
Carpet and Underlayment
Not enough people give the area where your feet go the thought it deserves. Covering your Mustang’s floorpans is more than just carpet, it’s protection and noise isolation. When it’s time to replace carpet, don’t forget the underlayment, those heavy petroleum-based mats that go underneath the carpet. We’re of the opinion that you should go one step further. Purchase some heavy plastic sheeting and lay it down between the underlayment and the carpet. This will keep moisture away from the steel floorpan if your cowl vent leaks or someone spills a Big Gulp.
