Marc Christ
January 25, 2010
Exhaust upgrades are usually one of the first things Mustang owners do. They are often fairly simple to install, not very expensive, and are manufactured by many different companies. We've done exhaust upgrades and tests on stock Stangs showing how much power you can make with just a few hours of work. This time, we've done things a little different.
We all know that the right set of headers will increase power, and they add a roar to the exhaust that most of us crave. The big question is whether to go with short-tube headers or the more racy, long-tube headers. Short-tube headers are often less expensive and easier to install, but you could be leaving some power on the table. So for this exhaust go-around, we've decided to test stock headers and a mid-pipe versus those common aftermarket pieces, and our test subject is an '05 GT five-speed-supercharged by a Magnacharger pumping out 8 psi. Can minor changes like headers and a mid-pipe make a noticeable improvement on such a vehicle? That is what we intend to find out.
We cruised over to the brand-new Brothers Performance supercenter in Deltona, Florida, to perform our tests. Brothers' East Coast facility is not only the distribution hub for all of its East Coast customers, but the 64,000-square-foot facility also features a retail showroom and a shop for installs, tuning, and dyno testing.
Other than the supercharger, our test GT had a Magnaflow after-cat system and was tuned with an SCT X3 tuner. With the help of Brothers Performance's Matthew Grieves, we strapped the Ford to the Dynojet and got busy. Baseline runs yielded 389 rwhp and 366 lb-ft of torque. The next step was to choose which headers and mid-pipe to use. Since BBK Performance is a leader in Mustang performance and Brothers carries the full line of BBK products, we swiped a few combinations off the shelf and started disassembling our test subject.
We started with the BBK chrome short-tube headers (PN BBK 1612), the least expensive ($299.99) and most popular of BBK's short-tube line. Ceramic coated (PN BBK 16120) and stainless steel (PN BBK 16125) are also available. With the shorties in place, we reinstalled the stock mid-pipe and made another dyno run. This yielded gains of 3 hp and 3 lb-ft at the peaks, bringing our totals to 392 rwhp and 369 rwtq at 6,250 rpm, however, this did not tell the entire story. That's because there were much bigger gains under the peak. For instance, at 4,400 rpm the engine picked up over 10 hp. This trend continued throughout our entire test.
With the shorties still in place, Grieves dropped the stock mid-pipe for BBK's X-style mid-pipe with cats (PN 1770). It works with stock exhaust manifolds or BBK's shorty headers. With the O2 sensors plugged in and fittings tight, it was back to the Dynojet for another run.
Not surprisingly, the peak gain was only 1 hp and 1 lb-ft of torque. But, like the previous run, gains were as high as 10 hp and 15 lb-ft of torque over the rest of the graph. More impressive was how much smoother and consistent the graph was throughout the run. Also, this combination caused a spike in horsepower at our cutoff of 6,250 rpm. A small hike in the maximum rpm may have produced greater horsepower at the peak, but the car owner didn't want to turn up the rpm.
Last on our list was BBK long-tube headers and matching X-style mid-pipe. Since this combination was going to be last, and permanent, we opted for the BBK stainless steel long-tube headers (PN BBK 16415) to couple with the X-style mid-pipe with cats (PN BBK 1637).
