5.0 Mustang & Super Fords
JPC Racing's CNC Stage 1 Coyote Cylinder Heads And Cams Install - Beefed Up
Terry 'Beefcake' Reeves puts JPC Racing's CNC Stage 1 cylinder heads and cams to the test
When the '11 Mustang GT hit the streets with the new Coyote 5.0 engine, the news was the engine was pretty well maxed out as far as power production. Of course, that just makes the aftermarket want to work harder to challenge that theory.
Right away, shops and engine builders wanted to see if that was true or not. We know of a few '11 GTs that were freed from their heads to see if there was improvement to be had, but minimum gain was reported. Maybe our contacts within Ford were correct in saying the engine's power output was maxed out?
Always one for going against the grain in the name of increased horsepower, Justin Burcham from JPC Racing didn't prescribe to the notion that the engine had nothing left to offer. Of course, he has one of the best engine builders on his side in Rich Groh from RGR Engines. Together, Rich and Justin have put their resources together to win multiple NMRA championships, and countless wins in numerous classes. If anyone could get more power out of these engines, Justin and Rich are the ones that could do it.
As such, they put their heads together to formulate a plan for more power. The duo worked together on a CNC program and camshaft design. Once the duo were done working their magic, they needed a car to try them on. The boys wanted a proven car, and one that would get attention, and be seen on a national stage. The heads and cams landed at Terry Reeves' doorstep.
Don't know that name, huh? Do you know the name Beefcake? More than likely you've heard of Beefcake and not Terry Reeves, but they're one in the same. Beefcake is Terry's nickname. He also goes by Meat Pie, as well, but he would prefer Beefcake.
Beefcake has been on the Ford performance case for several years now in a variety of Ford vehicles. Working as a salesman at Beechmont Ford in Cincinnati, Ohio, Beefcake has the inside line on new Ford vehicles, and he's not one to shy away from putting the screws to a new vehicle, even drag racing a new Taurus SHO a couple years ago. Mustangs are generally Beefcake's choice, and as soon as the '11 Mustang GTs hit the lot, he scooped one up for his latest "race car."
Competing in the NMRA's Super 'Stang class, Beefcake enjoyed instant success. Knowing he was going to compete at every event, Justin knew he was the ideal candidate for the heads and cams. Beefcake's GT already served as a testbed for other performance products so his car was the perfect candidate.
The heads chosen for Beefcake's GT are RGR/JPC CNC Stage 1 units. The heads feature a RGR custom competition valve job, custom machining of the stock intake and exhaust valves, and new bronze valve guides, seals, locks, retainers, and springs. RGR/JPC has both Stage 1 and Stage 2 heads available, but for Beefcake's car, the Stage 1 heads were chosen for this test.
To go along with improved cylinder heads, RGR/JPC offers cam grinds in both naturally aspirated and blower-specific applications. JPC calls them its Stage 1 N/A, and Stage 1 Blower grinds. Remember, with a Four-Valve engine, there are four cams—one for the exhaust, and one for the intake on each cylinder head. The Stage 1 blower grinds in Beefcake's engine feature 225 degrees of duration at 0.050 on the intake side and 235 degrees of duration on the exhaust side. Lift numbers come in at 0.470-inch on the intake, and 0.450-inch on the exhaust side. Justin says the lift numbers are stock, but the magic comes from the extended duration built into the cams. The increased duration keeps the valves open longer, which allows the engine to take in and exit more air than the stock cams.
Beefcake's GT received the blower grinds because his GT features a Vortech JT-Trim supercharger system, but before we give away any more information, let's get the install, which took place at Finish Line Performance in Milford, Ohio. Beefcake is such a valued customer that Finish Line Performance's website has a Beefcake's Corner page.
Horse Sense: If you are looking for one-stop shopping, JPC Racing offers an '11-'12 Mustang GT 500hp Top Dog package (Starting at $5,795.95), consisting of a JPC full exhaust, JPC/RGR CNC‘d heads and cams, a Boss intake, a JLT Performance cold-air intake, new head gaskets and head bolts, and a JPC-tuned SCT SF3 tuner.
On The Dyno
To make sure he wouldn't scatter a short-block during this test, Beefcake selected Manley rods and Diamond Racing pistons to withstand the boost. Topped with the stock heads and cams, the built short-block received its boost from a Vortech JT-Trim. In that form, Beefcake raced the car at the NMRA 2011 Bradenton opener.
The car went back to Finish Line Performance for the RGR/JPC CNC Stage 1 heads and Stage 1 blower cams. The results are shown in the dyno graph from Dog House Racing's Dynojet.
Notice the stock cams and heads give out around 6,600 rpm, but the RGR/JPC heads and cams extend the power band all the way up to 7,500 rpm. In any powerplant, rpm equals horsepower, but when you're relying on crankshaft speed, the higher the rpm the more horsepower is possible. Since a centrifugal supercharger relies heavily on crankshaft speed, the RGR/JPC heads and cams shine even brighter, allowing the Beefcake's engine to rev to the moon and make power all the way up.
Case in point, before the heads and cams were swapped, peak power came in at 6,000 rpm, but with the RGR/JPC heads and cams, peak power moved up to 7,200 rpm. With the stock heads and cams, peak power equaled 585 horsepower, but with the RGR/JPC heads and cams, that number jumped to 637 horsepower. Torque numbers followed suit, up from 486 lb-ft to 504 lb-ft.
Heads & Cams
Stock | RGR/JPC | Difference | ||||
RPM | HP | TQ | HP | TQ | HP | TQ |
4,000 | 310.20 | 407.34 | 301.49 | 395.84 | -8.71 | -11.50 |
4,100 | 315.13 | 403.67 | 317.84 | 407.12 | 2.71 | 3.45 |
4,200 | 339.34 | 424.28 | 340.32 | 425.53 | 0.98 | 1.25 |
4,300 | 364.29 | 444.92 | 364.23 | 444.86 | -0.06 | -0.06 |
4,400 | 377.78 | 450.94 | 379.29 | 452.73 | 1.51 | 1.79 |
4,500 | 385.92 | 450.44 | 389.55 | 454.65 | 3.63 | 4.21 |
4,600 | 396.55 | 452.74 | 396.26 | 452.44 | -0.29 | -0.30 |
4,700 | 411.47 | 459.80 | 408.73 | 456.74 | -2.74 | -3.06 |
4,800 | 420.26 | 459.86 | 421.43 | 461.12 | 1.17 | 1.26 |
4,900 | 434.98 | 466.22 | 436.34 | 467.67 | 1.36 | 1.45 |
5,000 | 448.39 | 471.00 | 453.79 | 476.66 | 5.40 | 5.66 |
5,100 | 460.04 | 473.74 | 475.11 | 489.25 | 15.07 | 15.51 |
5,200 | 478.42 | 483.21 | 490.91 | 495.84 | 12.49 | 12.63 |
5,300 | 491.16 | 486.72 | 502.54 | 497.98 | 11.38 | 11.26 |
5,400 | 498.06 | 484.40 | 515.93 | 501.80 | 17.87 | 17.40 |
5,500 | 509.27 | 486.33 | 518.16 | 494.83 | 8.89 | 8.50 |
5,600 | 514.23 | 482.29 | 532.16 | 499.07 | 17.93 | 16.78 |
5,700 | 527.40 | 485.95 | 546.92 | 503.95 | 19.52 | 18.00 |
5,800 | 535.47 | 484.89 | 554.08 | 501.74 | 18.61 | 16.85 |
5,900 | 543.84 | 484.12 | 563.70 | 501.80 | 19.86 | 17.68 |
6,000 | 552.77 | 483.86 | 571.20 | 500.00 | 18.43 | 16.14 |
6,100 | 562.52 | 484.33 | 584.89 | 503.59 | 22.37 | 19.26 |
6,200 | 571.38 | 484.04 | 594.95 | 504.00 | 23.57 | 19.96 |
6,300 | 572.57 | 477.33 | 601.73 | 501.64 | 29.16 | 24.31 |
6,400 | 581.72 | 477.38 | 607.65 | 498.67 | 25.93 | 21.29 |
6,500 | 577.62 | 466.73 | 613.59 | 495.79 | 35.97 | 29.06 |
6,600 | 585.01 | 465.55 | 619.59 | 493.08 | 34.58 | 27.53 |
6,700 | 579.81 | 454.52 | 625.96 | 490.67 | 46.15 | 36.15 |
6,800 | 577.25 | 445.87 | 625.37 | 483.03 | 48.12 | 37.16 |
6,900 | 570.29 | 434.11 | 632.20 | 481.22 | 61.91 | 47.11 |
7,000 | 573.46 | 430.26 | 628.28 | 471.40 | 54.82 | 41.14 |
7,100 | 559.91 | 414.17 | 623.19 | 461.02 | 63.28 | 46.85 |
7,200 | n/a | n/a | 632.62 | 461.45 | n/a | n/a |
7,300 | n/a | n/a | 635.19 | 457.00 | n/a | n/a |
7,400 | n/a | n/a | 634.31 | 450.21 | n/a | n/a |
7,500 | n/a | n/a | 634.88 | 444.60 | n/a | n/a |
7,600 | n/a | n/a | 629.64 | 435.13 | n/a | n/a |
