KJ Jones Senior Technical Editor
July 20, 2007
Photos By: KJ Jones
Horse Sense: Running a carburetor on a mod motor is a concept we here at 5.0 Mustang & Super Fords like to think of as teaching a new dog an old trick.
Sometimes we wonder if the prophetic statement "time does not stand still," was first said by someone associated with the form of high performance there was back when the phrase was coined-chariots, horse and buggies, whatever.
Time, with respect to the innovations and technologies for Mustangs we experience on what seems to be a daily basis, certainly doesn't stay in one place. Manufacturers are always developing parts intended to make 'Stangs better, stronger, and faster. Our job is to make you aware of all the latest and greatest parts as soon as we find out about them.
This is the mod squad we're installing on a supercharged, 4.6-powered '04 Mustang GT. The pieces include eight new MSD Blaster coil-on-plugs (PN 82428; $388.60), a complete 6-Mod ignition controller system (PN 6011; $411.00), and a harness for EFI (PN 88814; $285.70).
MSD Ignition has just taken the wrap off its new 6-Mod ignition (timing) controller (PN 6011; $411.00) for Two- and Four-Valve modulars, as well as Ford Blaster coil-on-plugs (PN 82428; $388.60/set of eight) for SOHC 4.6s. The timing couldn't be better.
MSD's 6-Mod essentially bridges the canyon that separates modular engines and the ability to run them with carburetors. The absence of distributors in '96-to-present 'Stangs has long been a major hurdle for a happy marriage between the two, as control of ignition and timing was all but impossible to achieve when carb swaps were attempted.
Timing control is 6-Mod's fort. For a carb application, the unit assumes the same role that weights and springs take on inside a distributor. But 6-Mod isn't strictly for carb swaps; it suits street/strip 4.6s and 5.4 EFI applications. It's quickly and easily installed using an optional harness for EFI (PN 88814; $285.70). The system is all-inclusive with a complete harness, two-bar MAP sensor, and ProData+ software. The only thing not included is the laptop computer used to program custom timing curves based on MAP or rpm and dialing-in step retards, rev limits, and two-step settings, if desired.
Our test Pony packs this Vortech S-Trim supercharger, which features an eight-rib beltdrive for better belt traction. The 'Stang's engine is stock, save for the blower, so boost is limited to a safe 10-pound range to ensure there are no detonation issues with 91-octane California gas.
Our friends at Extreme Automotive have a supercharged '04 Mustang GT that's due for tuning-which is something timing plays a huge role in. We're seizing the opportunity to install and test 6-Mod and MSD's new COPs. In actuality, a Mustang with a carbureted 4.6 would be an even better test vehicle. That said, we don't have a non-EFI mod motor at our disposal, nor do we have the time to delve into a carburetor swap for this exercise.
Our plan is to try and optimize the blown EFI 'Stang's tune and make power by using the controller's built-in timing source. This is 6-Mod's most basic adjustment method, and we recommend you use it as a starting point if you're new to laptop tuning.
With the built-in timing source, 6-Mod processes a PCM's timing and presents a new baseline timing curve that can be modified (advanced or slowed) by clicking on and dragging the dots in ProData+'s rpm or MAP tables. Data is then transferred and saved in the tables from the laptop to the 6-Mod controller unit mounted in the engine compartment. The system also offers more dynamic methods of manipulating an injected mod-motor's timing, but again, we suggest you stick with the built-in basic feature until you're more familiar and comfortable with operating 6-Mod.
Continue reading and learn more about our exploits with MSD's new 6-Mod ignition controller and the overall performance of the blown '04 when spark and timing are at their best.
Saul "The Surgeon" Gutierrez of Extreme Auto-motive orchestrated our installation and dyno tests. The process begins with the removal of the air-charge cooler's tubing, which creates more than adequate access to the coils on the passenger side of the engine. Even though our test subject is equipped with a strut-tower brace, removal isn't necessary.
Ford Blaster Coil-on-Plugs bolt directly in place with no changes or mods required. The COPs provide higher voltage and greater spark energy than factory coils, thanks to MSD's patented, dual-magnet technology. By emitting spark energy directly from the coil and across the spark-plug gap instead of at the wire in the boot, combustion and engine efficiency are greatly improved with Blasters.
On The Dyno
  Stock Coils   MSD Blaster Coils   Difference
RPM Power Torque A/F Power Torque A/F Power Torque A/F
2,750 137.33 254.88 10.40 148.62 273.92 10.50 11.29 19.04 0.10
2,803 146.22 261.98 10.44 150.71 275.24 10.51 4.49 13.26 0.07
2,890 153.66 266.94 10.44 158.66 280.23 10.51 5.00 13.29 0.07
3,004 163.24 272.86 10.46 169.61 286.34 10.55 6.37 13.48 0.09
3,092 170.30 276.55 10.46 174.83 288.21 10.61 4.53 11.67 0.15
3,192 179.06 281.70 10.67 183.81 293.97 10.65 4.75 12.27 -0.02
3,300 190.35 289.61 10.71 199.18 305.19 10.55 8.83 15.59 -0.16
3,393 201.08 297.58 10.86 208.90 312.82 10.59 7.82 15.24 -0.27
3,510 216.03 309.05 10.96 224.89 324.58 11.00 8.86 15.53 0.04
3,602 226.25 315.38 10.86 235.30 331.46 11.07 9.05 16.08 0.21
3,701 237.20 321.85 10.88 245.76 337.23 11.25 8.56 15.38 0.37
3,797 247.09 326.81 10.92 256.80 343.03 11.38 9.71 16.22 0.46
3,907 258.26 331.88 10.98 267.77 348.22 11.55 9.51 16.34 0.57
3,995 267.53 336.24 11.03 278.28 352.16 11.65 10.75 15.92 0.62
4,093 277.54 340.50 10.78 286.05 354.27 11.75 8.51 13.77 0.97
4,199 286.90 343.13 10.82 294.77 356.56 11.61 7.87 13.43 0.79
4,292 293.97 343.95 10.96 305.44 360.68 11.42 11.47 16.73 0.46
4,399 301.02 343.60 10.80 315.59 363.26 11.30 14.57 19.66 0.50
4,509 308.22 343.24 10.92 323.63 365.24 11.30 15.41 22.00 0.38
4,592 313.33 342.62 10.96 333.89 367.71 11.42 20.56 25.09 0.46
4,706 320.18 341.63 10.98 342.26 368.55 11.52 22.09 26.93 0.54
4,811 325.84 340.13 10.86 348.22 368.16 11.50 22.38 28.04 0.64
4,895 329.27 337.80 10.75 356.12 368.30 11.48 26.85 30.50 0.73
4,996 331.00 332.66 10.69 361.51 366.10 11.44 30.51 33.44 0.75
5,094 332.85 328.08 10.80 364.48 361.49 11.46 31.64 33.41 0.66
5,196 331.78 320.62 10.75 366.36 355.87 11.50 34.59 35.25 0.75
5,308 329.81 311.99 10.63 368.45 351.70 11.63 38.64 39.71 1.00
5,375 329.05 307.43 10.65 369.82 348.56 11.61 40.76 41.13 0.96
The MSD Blaster COP on the right doesn't appear to be any different than a stocker. Their housings are exactly the same.
Prior to beginning our project, we tested the Vortech-blown, '04 Mustang GT on Extreme Automotive's Dynapack Evolution 4000 chassis dyno. We were trying to determine whether the swap from stock coils to MSD's Ford Blaster coil-on-plugs would make any difference in the 'Stang's rear-wheel power and torque output.
Thanks to the bigger spark blast, we saw a sizeable gain in horses and torque with MSD's coil-on-plugs. More importantly, our air/fuel mixture took a turn from being somewhat rich in the mid 10s to a more acceptable mid-11 ratio with blasters installed.
Since we're using 6-Mod in an EFI application, this EFI harness kit is required. It includes splice-free connectors that plug directly into the crankshaft and camshaft sensors and the 6-Mod wiring harness. Also included is a tach adapter that completes the circuit between the factory harness and 6-Mod harness at the number-one cylinder. The adapter provides a tach signal to the controller based on the firing of the number-one cylinder. The controller uses this to read the engine's timing. Seven individual coil adapters that plug into the factory harness and fires coils for all other cylinders are also in the kit.
Saul lays out the wiring harness from our 6-Mod controller. The harness is secured with a multi-pin WeatherPak connector and includes factory-style plugs for the cam and crankshaft sensors, each COP, and the MAP sensor.
Cylinder number one is the source of the tach signal that 6-Mod requires for use with EFI. This adapter (PN 88814) must be connected to the factory and 6-Mod wiring for coil number one.
The brown and tan harness is linked to the camshaft sensor, which is located near the top of the engine's front cover on the driver side. The crankshaft sensor is mounted at the bottom of the cover on the passenger side near the crank pulley, and it also receives a harness, which is identified by its red and black wires. Each one is plugged into the factory and 6-Mod wiring and the sensors on the engine.
Changing Times
6-MOD W/18-DEGREES
TIMING ADVANCE
2,001 99.89 250.52 10.11
2,103 101.72 242.72 10.11
2,190 104.92 240.43 10.11
2,302 109.88 239.56 10.05
2,400 114.48 239.38 10.13
2,491 120.62 243.02 10.23
2,602 130.29 251.30 10.46
2,696 138.18 257.20 10.67
2,803 147.29 263.70 10.69
2,895 154.94 268.65 10.69
2,989 162.68 273.19 10.69
3,109 173.22 279.66 10.75
3,202 182.31 285.80 10.94
3,292 191.81 292.52 10.80
3,404 205.24 302.64 10.98
3,498 216.45 310.60 10.98
3,598 229.40 320.10 11.00
3,690 239.96 326.45 11.11
3,790 251.08 332.57 11.42
3,896 263.50 339.56 11.32
4,008 277.01 346.99 11.50
4,099 287.79 352.44 11.50
4,211 300.64 358.39 11.26
4,293 309.48 361.85 11.25
4,407 319.76 364.12 11.00
4,495 327.23 365.36 11.09
4,607 335.83 365.85 10.98
4,696 342.93 366.51 11.07
4,802 350.78 366.67 11.00
4,892 356.87 366.12 10.98
5,004 363.88 364.98 10.98
5,090 367.69 362.59 10.98
5,205 371.80 358.60 11.00
5,295 374.31 354.82 11.03
5,402 376.46 349.79 10.98
5,447 377.07 347.49 10.98
MSD's 6-Mod ignition (timing) controller proved to be a cool deal. Using the unit's built-in mode to give us a baseline, we created, stored, and transferred timing-advance and retard changes in 6-Mod's MAP and rpm tables.
A nine-pin serial cable links 6-Mod with the MSD ProData+ program we installed in our laptop. Beginning on the tuning side involves plugging up and following the on-screen prompts for loading the software.
Fine-tuned ignition timing proved to be a key to increasing rpm and making more horsepower; keep in mind that we use 91-octane fuel when we're on the dyno. In addition to the gains we achieved after installing hotter coil-on-plugs, it improved our blown-modular's air/fuel ratio. The mixture leaned to 11.0s under boost/3,500 rpm, from 10.7s with no timing.
In the MAP table, we began with 15 degrees timing at 0.0 MAP pressure. At 0.4 pressure on this scale, timing was advanced to 25 degrees. At this point, we tapered off timing between 0.4 and 15 MAP pressure and stored our curve with a final 18-degrees advance at Wide Open Throttle. As MAP/boost increases, it's normal to retard timing when using pump gas to ward off detonation.
On the rpm side, we also worked our way up from 15 degrees timing at 0.0 rpm and dialed in 25 degrees when the tach read 1,500 rpm. Following the same rule of retard that we adhere to with MAP, our rpm-based timing curve was tapered off to a final 10 degrees at WOT.
Timing curves can be created and modified by clicking and dragging dots that are plotted on either of two tables (rpm and MAP). We adjusted timing using the system's built-in mode, which presents 6-Mod's interpretation of the engine's timing, from which advance or retard adjustments are made.
The unit's wiring harness is universal, so there's more than enough wire to mount a 6-Mod controller nearly anywhere in an engine compartment. Since we're not using the step-retard or two-step features, Saul isolates their wires, tapes off the ends, and zip-ties the wires together before tucking them out of sight.
A good ground is essential to the proper function of any electrical component. Saul joins the ground wire of 6-Mod's harness with a hood ground on the 'Stang.
We were initially concerned about how we would arrange each coil adapter around the engine to keep them from being damaged. Each adapter features a loop built into its case that allows us to slip a zip tie through it and secure the adapter to 6-Mod's harness.
Our 6-Mod kit included a GM-style-we know it's wrong, but we have to go with what works best-two-bar MAP sensor. It feeds the controller the engine's vacuum pressure as load increases. A MAP sensor monitors the changes in the intake manifold or vacuum pressure during various engine operating loads and sends a corresponding signal to the PCM.
