February 13, 2014
When Ford introduced the all-new 4.6L single overhead cam V-8 in the Lincoln Town Car in 1991, many were underwhelmed. A 281ci cammer in a fat overstuffed Lincoln? Many people saw the new Modular V-8 as an engine that could never be built for performance use, nor could it keep up with the pushrod classics like the small- and big-blocks. It wasn't the end, but instead, the beginning of a new era of powerful low-displacement Ford V-8 screamers leading up to the hot 5.0L Coyote V-8 20 years later.
What most lacked in 1991 was an understanding of Ford's new overhead cam V-8. If you've never been intimately involved with the 4.6L and 5.4L Modular engines, they're intimidating. Pop the cam and front timing cover and the Modular mill is a confusing series of chains, guides, and valvetrain components. It is surely large. Pull the comparatively large SOHC heads and it is smaller than your 5.0L High Output small-block. Though it consumes a lot of space, the Mod' is also long on potential, durability and power.
Before you can build the Modular, you've got to understand the Modular. This is not an engine forgiving of error, even small ones. If you approach this engine sans proper understanding, it gets costly and time consuming. The objective of this article is to help you get it right.
The Modular overhead cam V-8 combines a number of great attributes from past engines. The Modular block is skirted like an old FE or the Y-block; it is cross-bolted like the legendary 427, yet compact like a small-block.
From a more traditional standpoint, the Modular's bore and stroke don't make much sense. The 4.6L is a "square" engine with a 3.552-inch bore and a 3.543-inch stroke configured on 3.937 bore spacing. Take the same 3.552-inch bore and add a little more than one-half inch (0.622-inch) of stroke to 4.165-inches and you have the 5.4L engine. The down side to both Modular engines is the dynamics of these bore/stroke combinations. They do not make good low-end torque. These are engines that like to rev with peak torque coming in higher than traditional Ford V-8s.
Modular Timeline
When the 4.6L SOHC Modular V-8 was introduced, it was a standalone engine built in one engine plant—Romeo, Michigan—the former Ford Tractor division factory left empty when Ford sold the division to New Holland. In the beginning, the Modular V-8 was simple to understand because there was one plant and one basic 4.6L SOHC engine. The 32-valve 4.6L DOHC came next for 1993 in the Lincoln Mark VIII; also produced at Romeo.
When the Windsor, Ontario engine plant began building the 4.6L and 5.4L SOHC engines in 1996, mostly for trucks and sport utilities, this engine family became more complicated with the two plants generating engines with slightly different architectures. You'll want to be aware of the varied differences among the Modular engines when planning your engine build; Romeo and Windsor engines are different, with minimum interchange of parts.
1. Head on, the 4.6L SOHC engine is expansive and to some degree, intimidating. It is wider than the Boss 429 and on a par with the vintage 427 SOHC in terms of size. It requires a wide engine bay. If you’re planning a Modular swap for your Mustang or Fairlane, plan on shock tower modification or elimination, because it will not clear the towers. This 2V SOHC Modular is missing its induction system, which is either cast-aluminum long runner (trucks) or plastic short runner (cars)
2. This is the 4.6L Modular short-block minus cylinder heads. When you study this engine’s architecture, you find incredible ruggedness in its cross-bolted and skirted design with a lot of webbing, which is where its strength comes from. The Modular V-8 is a new generation of Ford engineering mindset. Ford spent a lot of money developing the Modular V-8 and fully intended for this engine to be in production for decades and across several car and truck lines. Because millions of these engines have been produced, there are a lot of cores out there to build from. Ford continues to produce new block and head castings, which are available through Ford Racing Performance Parts and its dealers.
3. Head on, the 4.6L Romeo block looks like this. A lot of them have the “R” indicating a Romeo block, which is different than a Windsor block, and very little is interchangeable. The Romeo block has jackscrew cross-bolted main caps.
4. Side by side are the 5.4L SOHC block (left) and the 4.6L block (right). The 5.4L engine is Windsor-only with a taller deck than the 4.6L. The 4.6L engine was produced at both Romeo and Windsor, but with different nuances you need to be aware of. Look for the “R” on Romeo block, though not all will have it. Windsor blocks have a “W.”
5. This is the bottom end of a Windsor block with dowel style cross-bolted main caps. These dowels provide support between the main caps and the block. Cross-bolts pass through each dowel.
6a. Romeo 4.6 blocks have internally threaded, jackscrew-style main caps. Once the main caps are properly torqued, jackscrews are threaded out to where they touch the block skirt, and then bolts are installed and torqued using sealer under the bolt head to prevent oil leakage.
6b. Where the Windsor block differs is dowel pins that wedge into place once main caps are torqued.
7. This is a 4.6L Windsor block with dowel-style main caps. Think truck when you think of the Windsor engine plant. Engineering is angled with rough duty in mind. The strongest iron blocks are from the Windsor foundry and plant. The dowel pins support the main caps and are driven in with a mallet. Once seated, install the cross bolts and torque to Ford specifications.
8. Where Modulars differ from FE, Clevelands, and small-blocks is a shim-style thrust bearing at the Number 5 main cap. Shims are of varying thicknesses to get just the right crankshaft endplay. Having the thrust at Number 5 is a GM nuance, which makes it odd in the Ford camp.
9. According to author George Reid’s excellent How-To Rebuild 4.6L/5.4-Liter Ford Engines book from CarTech Books, all SOHC Modulars have cracked powdered metal connecting rods with cap screws. Though powdered metal sounds wimpy, it is actually a strong connecting rod that will take up to 500 horsepower according to Reid, though it is suggested you opt for a good Manley rod if you’re going above 450 horsepower. Most of this decision is centered on how hard you intend to run your engine and for how long.
Boss Block
If you're going to build a 4.6L low-deck engine from scratch, begin with either a new Romeo off-the-shelf block or the 5.0L iron BOSS block (M-6010-BOSS50) from Ford Racing. This BOSS50 block, which is cast at the Cleveland foundry, has the 4.6L deck height and 94mm cylinder bores along with 17mm minimum main web thickness. Main caps are interference fit void of jackscrews and dowels. Though the 4.6L Romeo and Windsor blocks are rugged, this one you can really put to the test. Engine mount bolt patterns are 4.6L iron block style. An adaptor plate is available if you intend to use this block in a 3V aluminum block application. You can lasso the BOSS50 block for about $1,369 plus shipping, handling, and taxes.
Reciprocating Parts
10. The Modular’s oil pump is crank driven, which makes it decidedly different than your vintage V-8. Oil pump installation calls for perfect centering of the pump on the crank before tightening bolts. The pump cannot sit on the crank or be offset in any way. If it does, pump damage and failure will result. Run the DOHC/Cobra high volume pump (F8OZ-6600-AA). Some pick-up modification is required when you run this pump. Melling offers a high-volume steel billet pump for Modular engines (#10227) as does Ford Racing (M-6600-D46), which includes the pump and pick-up.
11. Here are the two factory oil pumps side by side. According to George Reid’s 4.6L/5.4L book, the high-volume Cobra/DOHC oil pump is the pump of choice for your SOHC. As you can see the Cobra pump has larger passages yielding higher volume, but not higher pressure. You will need to perform pick-up modifications to install this pump on a SOHC engine.
12. Reluctors and gears changed in 1996. On the left is the ’91-’96 thick steel reluctor (trigger wheel). On the right is the ’96-up thinner stamped steel reluctor and crank gear with a space to make up for the difference in reluctor thickness. Although there has been some confusion on which way the stamped reluctor teeth face, it is always toward the timing cover and away from the engine block. Point these teeth toward the block and you will experience engine damage due to teeth and chain interference.
13. Another great advance in the 20-year-old Modular engine is its lightweight valvetrain consisting of stamped steel roller cam followers and compact hydraulic tappets (lifters/followers), downsized valves and springs, and composite cam technology—no pushrods to fumble with here. The Modular’s overhead cam design eliminates the excess of overhead valve/cam in block mindset. Roller technology reduces internal friction.
14. The Modular’s composite cam with larger swaged-on lobes for reduced friction yet with a more aggressive profile. It is the larger lobe that allows the roller rocker to navigate the lobe more smoothly and with less friction. Note there are no cam bearings. Cam rides directly on the journal with an oil wedge to carry the load.
15. This is a Romeo non-PI (Performance Improved) head (prior to 1999) with the comma-shaped intake ports. Romeo SOHC heads have this cam girdle as well.
16. This is the Romeo non-PI head 51cc chamber. The smaller 42cc PI chamber offers improved high-swirl performance and greater compression ratio for more power.
Reciprocating Parts Cont.
There has always been debate about the integrity of powdered-metal connecting rods common in Modular engines. In more than 22 years of Modular V-8 production from two engine plants, these rods have never been problematic when employed in stock or lightly modified engines. In short, you can hammer the daylights out of them and still have a reliable engine.
The supercharged 2003 4.6L Cobra DOHC engines had steel Manley rods and forged pistons for endurance—one exception is the 2000 Cobra DOHC with forged steel Carillo rods. If you stumble upon an '07-'11 Shelby GT500 donor or crate engine, it will also be fitted with Manley rods. Yet every other Modular including the 3V that arrived in 2004 has been factory fitted with powdered metal connecting rods. Another popular misconception according to author George Reid is that Modular engines all came with forged pistons, which has never been true. From the factory, all Modular engines (except the '03-'04 DOHC 4.6 Cobra), including the 3V and DOHC versions, had high silicon hypereutectic pistons. The beauty of hypereutectic versus forged is expansion properties. Forged pistons yield greater expansion, which calls for a loose cold fit. Cold knock until the engine warms up is often a side effect of the loose fit. The same can be said for hypereutectic pistons in that they tend to knock cold, but warm and expand more quickly than forged.
17. This is a Windsor PI head. Do you see the difference? The Windsor head doesn’t have a cam girdle like we see with the Romeo casting. This is also a PI (Performance Improved) head with smaller chambers, larger exhaust valves, and these modified teardrop intake ports for better flow.
18. Modular heads get virtually the same treatment as any other cylinder head. Because they are aluminum, the mill runs at a higher speed. Main thing to watch is how much material you remove, which affects chamber size.
19. These are the hydraulic followers/lifters, which fit into oil pressurized bores keeping the roller rockers against the cam lobes. No adjustment is required.
20. All of the 2V SOHC heads are omnidirectional meaning you may install them on either side. However, keep oil passages in mind when you do. Chain tension actuators install at the front end of each cylinder head. The end of the head facing your firewall must have oil gallery plugs where tensioners would go in front.
21. JGM Performance Engineering does a lot of Modular engines. Valve stems get Viton seals for longevity and exceptional oil control.
22. When it is time to hang timing chains, Ford makes it easy to find and align timing marks. Dark links connect with dots on each camshaft sprocket. Links down below match the crank sprocket. You’d have to work real hard to mess this up. This is the left cylinder head cam sprocket. The righthand cam sprocket works the same way with two dots and a dark link.
23. Two timing chain tensioners get oil pressure and apply tension to the chain guides. Any time you rebuild a Modular engine, install new chain guides and tensioners regardless of condition. Better safe than sorry.
24. Each cam should be degreed just like you would do with your conventional Ford V-8. Degreeing takes all of the doubt out of cam specifications by demonstrating exactly what you have for a camshaft as it relates to piston and valve timing events.
25. Modular engines have the best sealing in the history of Ford engine development. If installed properly and checked for proper fit, they will last the life of your engine. Here, Fel-Pro gaskets are being used. If you are building a BOSS50 block, you will need Cometic cylinder head gaskets due to the larger bore size.
26. Cylinder head gaskets get a dab of Permatex’s The Right Stuff in the corners to head off any oil weepage that could occur here from oil drain back.
27. The Modular has a separate bolt-on cast-aluminum rear main seal cover with a one-piece seal making rear main seal replacement easy should you ever have to do it. Because the SOHC Modular engine is virtually leak free when properly assembled, you should never have to worry about this. The seal lip and spring go toward the engine. Pack the seal lip with engine assembly lube to prevent spring loss during installation. If you lose the spring, it will leak.
28. SOHC intake manifolds are limited to the truck/sport utility tall cast aluminum/plastic combo piece (doesnt fit under a Mustang hood), and this plastic passenger car intake manifold common to the Mustang GT, Crown Victoria, Grand Marquis, and E-Series vans. 2001 Bullitt Mustangs were equipped with a unique cast aluminum piece, and a number of aftermarket aluminum manifolds are now available.
Crankshaft/Balancer Identification
There are two basic crankshaft types used in all Modular engines—six- and eight-hole nodular iron. The eight-hole cranks are Windsor or high-performance Romeo, according to George Reid. Reid adds that since 1991, when production began, there have been a few basic cranks used in all Modular engines. All are nodular iron. Sean Hyland of Sean Hyland Motorsports, who builds and races a lot of Modular engines annually, told Reid he's never seen anyone break these crankshafts. The nodular iron crank is good for up to 500 horsepower. Given a choice between six-hole and eight-hole, choose the eight-hole flange. There are two crankshaft weights available—heavy and lightweight. The quickest way to identify is the balancing holes in the counterweights. Heavy cranks were made for heavier connecting rods, which first entered service in 1996.
There is the steel eight-hole M-6303-D46 DOHC/Cobra crank you can drop right into the SOHC block. Some minor block modifications may have to be made to prevent block and counterweight interference. If you're building a 5.4L SOHC, there is a steel crank available, M-6303-M54, with an eight-hole flange.
Another closely related issue is the harmonic balancer. There are three basic types for the Modular engine—six-rib for 4.6L, wider six-rib for Cobra/DOHC, and the eight-rib for 5.4L engines. There are also aftermarket balancers for the Modular engine, which tend to follow the six- and eight-rib rule.
Torque To Yield?
Torque to yield is a long-practiced concept designed to prevent over tightening. These fasteners are easily identified by a slight bevel or taper below the bolt head.
Their use calls for tightening them to Ford's specification, then tightening them the suggested additional number of rotational degrees. Torque to yield fasteners are a one-time use fastener—use them once and throw them away. Not all Modular engine fasteners are torque to yield, but cylinder head bolts surely are.
