Steve Baur
July 1, 2004
The Snow Performance Boost Cooler eliminates all the extra tubing that traditional intercoolers utilize. A pump, a tank and a controller are all you need.
0407mm_02z 1987_Ford_Mustang_LX_50 Underhood_Engine
Car owner Andrew Sivori (left) and Snow Performance proprietor Matt Snow (right) survey the real estate in order to plan the Boost Cooler's installation.
0407mm_03z 1987_Ford_Mustang_LX_50 Underhood_Fuel_Pressure_Regulator
Thanks to the Vortech supercharger, the vacancy left by the stock airbox will now house the methanol/water tank. Since the fuel pressure regulator had already been installed in the region, we needed to mount the pump in a different location. The pump should be mounted below the tank for gravity feed.
0407mm_04z 1987_Ford_Mustang_LX_50 Underhood_Removing_Intake_Tube
The Vortech inlet tube is removed so we can install the spray nozzle.
Use a 7/16-inch drill bit to make a pilot hole in the elbow. Then, a 1/4-18 NPT tap is used to cut through the soft aluminum tube.
The spray nozzle's pattern is designed for optimum coverage of the incoming air charge. This produces better atomization and mixing.
0407mm_07z 1987_Ford_Mustang_LX_50 Underhood_Cooler_Nozzle_Installed
We put a dab of Loctite sealant on the nozzle...
... and installed it into the intake tube.
Supercharging is fast becoming one of the most popular modifications to late-model Mustangs as 50-100 percent increases in horsepower and torque can be had without any other changes.
One of the byproducts of supercharging or compressing air is an increased air charge temperature--and at mild boost levels, this is not much of an issue. For greedy gearheads who like to pump up the manifold pressure, the higher air temperatures can result in pre-ignition and detonation, unless ignition timing (and subsequently power) is reduced. To combat this, some blower companies offer cooling units that use an air-to-air or air-to-water heat exchanger to cool the incoming charge, thus allowing you to use nearly the same amount of timing.
Injecting a small amount of nitrous oxide to cool the intake charge is also an alternative, but nitrous oxide isn't cheap, nor is the high-octane race fuel that many turn to. Snow Performance of Woodland Park, Colorado, offers an alternative that increases power without deflating your pocket book.
Methanol/water injection is a far more inexpensive option that allows you to safely increase ignition timing as well as manifold pressure or boost for improved performance. Its high latent heat of vaporization provides an increase in air density and this in turn results in better detonation control. And where an intercooler will reduce boost, the Boost Cooler will actually increase it.
The Snow Performance Boost Cooler kit is available in two stages. Stage One is for mild boost applications and includes a lower volume pump and adjustable boost pressure switch. Stage two includes an upgraded pump, as well as a boost dependent, variable control module to adjust the flow of the methanol/water mix. With the controller, a small quantity is injected at lower levels of boost with full injection at higher levels resulting in improved drivability. Retail prices are $299 and $399 respectively, and both kits include everything needed for installation with the exception of tools. You'll probably need to pick up the required 1/4-18 NPT tap and maybe a 7/16-inch drill bit, but basic hand tools and a drill are all that are needed. Installation takes approximately 3-4 hours.
Snow Performance's owner Matt Snow came out to the East Coast to assist in the installation of his kit on Andrew Sivori's '87 notchback. Sivori's coupe was a prime candidate for the Boost Cooler, as it was running moderately high boost from its Vortech T-trim supercharger with no intercooler. Although the Mustang is driven to and from the track, it doesn't see much street use otherwise, so Sivori had tuned the pony on 116-octane race gas. In this configuration, 549 rwhp and 523 rwtq was attained with 0 degrees of boost retard and 15 psi of boost. The power output is pretty stout given the relatively old-school engine combination.
Snow said we would see an increase over the race fuel, but he also explained that using the methanol/water combination with pump gas would result in more power than just race fuel alone. And one of the benefits to using this system is not having to fork over the money for expensive race fuel so we drained the tank and drove the car to the corner for some Amoco 93-octane.
We started with the timing retard set at 2 degrees and initial timing at 10 degrees. The Mustang turned the rollers to 493 hp and 477 lb-ft of torque and this would serve as our baseline as we were at 12.2:1 on our air/fuel ratio.
The kit directions include tuning tips for the controller. Snow set the variable controller to start injection at 3 psi and be in full swing at 5 psi. The methanol/water injection increased boost pressure 2 psi for a total of 17, but the air/fuel ratio took a dive, so we began making adjustments first to the timing retard, then to the fuel pressure and eventually the initial timing to lean it back out. Thanks to the Boost Cooler, we were able to decrease fuel pressure by 7 psi and increase initial timing to 13 degrees to bring back the air/fuel ratio to 12.5:1. This resulted in 571 hp and 516 lb-ft of torque at the wheels. That's over 78 hp from $1.50 worth of methanol.
Granted you have to factor in the cost of the Boost Cooler kit, but it's a far cry from the price of an intercooler and slightly less than a nitrous kit. After nearly a dozen runs on the dyno, we'd barely used an eighth of a tank of methanol and water. Talk about horsepower per dollar. The Boost Cooler also offers great results on diesel and naturally aspirated gasoline applications as well.
Test Vehicle at a Glance
'87 Mustang LX 5.0
  • Keith Craft 306ci short-block, balanced, stock crank and rods, forged TRW pistons
  • "Vintage" TFS Street Heat cylinder heads with 1.94/1.60 valves, ported by B&B Performance of New Jersey
  • Ford Racing X303 camshaft, installed straight-up
  • Trick Flow Specialties 1.6:1-ratio roller rocker arms
  • Ford Racing GT-40 intake manifold with ported lower
  • Ford Racing 65mm throttle body
  • Texas Turbo 1 3/4-inch long-tube headers, 3-inch exhaust, Dr. Gas X-Pipe, Flowmaster two-chamber mufflers
  • Pro-M 80mm mass air meter calibrated for fender-mount, supercharged application
  • 42-psi Ford Racing fuel injectors
  • Aeromotive sumped tank, A1000 pump, billet rails, boost referenced FPR
  • MSD 6A box, coil, and BTM
  • Approximate engine CR ratio: 9.8:1
  • 17-psi boost on dyno (max without Boost Cooler was 15 psi)
  • Vortech T-trim supercharger (2.75-inch pulley)
  • Anderson Ford Motorsport Power Pipe
