Miles Cook
February 21, 2006
Pro-Motorsports makes bumpsteer corrector kits in three applications for vintage Mustangs, including '65-'66, '67-'69, and '70-'73 cars. The main spacer and stirrup clamp are made of quenched and tempered 4140 chrome-moly steel, means these pieces are essentially indestructible. All the specialized hardware shown is included. Note the block at the upper left is assembled for one side, while the other disassembled parts are the setup for the other side.
According to Pro-Motorsports Engineering, manufacturers of the bumpsteer corrector kit we installed here, bumpsteer is a front-suspension design flaw of every vintage Mustang. On a car with a mostly stock front-suspension, the problem might not be as apparent, and our experience has proven this difference to be true.
How do we know? Well, our tried-and-true '69 fastback project car has once again been the basis for our research. When we first bought the car in early 2003, it had a stock front suspension that worked adequately but could certainly benefit from a thorough rebuild. One of the first things we did was install all-new pieces from Mustangs Plus' line of Grab-a-Trak components. At that point, the car drove well, handled with considerably more composure than before, and generally felt much safer at highway speeds.
Next on the agenda was the installation of a Flaming River (FR) rack-and-pinion steering system. Flaming River's excellent cradle-mounting system and solid-feel, fast-ratio rack was a step up in steering-feel and overall competence. However, by no fault of Flaming River, our car was a true oddball application with its 351W engine, four-speed clutch linkage, and JBA "mid-length" header flanges that are quite close to the steering-system's mid-shaft U-joint. In short, our car isn't your average 289-with-stock-manifolds-and-an-automatic-transmission combination. Nonetheless, Flaming River came up with a cradle--now a production part--that allows the rack to fit.
The plot thickened when, for our Nov. '05 issue, we installed Blue Moon upper and lower control arms, which put us in a situation where the arms' modified geometry combined with the Flaming River steering rack's relatively low mounting point caused horrendous bumpsteer (see sidebar). Again, as with the Flaming River rack, this was not something that could be blamed on the Blue Moon parts. In fact, the control arms are about the most bulletproof suspension parts we've seen--seemingly built like bridge girders.
1 Installing the Pro-Motorsports kits is easy considering the improvement. It can easily be done by the average do-it-yourselfer. However, a good suspension shop, such as Marlo's Frame, can do it and also set the proper toe-in (about 1/16-inch). With the car in the air and the wheels off, remove the cotter pin that holds the castle nut in place.
Along with the low-slung rack and the updated-geometry control arms, we also had a lower-than-stock ride height, which made the bumpsteer even worse. In short, our setup had the car all over the road when going over bumps, dips, potholes, and high-speed undulations.
So we got back in touch with Flaming River's technical department. Much to their credit, they mentioned that other customers had the same problem on their lowered cars. Note that we said "some," because not every FR rack-and-pinion setup mounts to a vintage Mustang in the exact same location, and not every car has a lower ride height that worsens bumpsteer.
After sending a few pictures to Flaming River showing the position of the tie-rods and how they angled up too much, the diagnosis was a serious case of bumpsteer. Flaming River immediately recommended Pro-Motorsports' corrector kit and told us that several customers had installed the same system with dramatic improvement. So after a trip to our local vintage Mustang front-suspension experts at Marlo's Frame and Alignment, we installed the Pro-Motorsports kit and achieved the improved result.
The car now goes straight as an arrow over all high-speed dips--something that's important to us as high-speed freeway road trips are common in this car. Bumps and potholes aren't nearly as scary as when the steering wheel was almost yanked out of our hands. Finally, note that the Pro-Motorsports' kit is available from Mustangs Plus.
