Courtney Barber
October 28, 2017
Photos By: Rob Kinnan, Emily Waters
Mustang Monthly readers are probably familiar with the author, Courtney Barber, of Team Mustang Girls (TeamMustangGirls.com). I worked with Mustang Monthly the last few years on Project Road Warrior, my 1965 Mustang hardtop. My Mustang and I have racked up roughly 150,000 miles in the year and a half since that project finished, including a trip to Alaska and back and a stint on the torturous Denali Highway, proving the toughness and reliability of the parts we used on the car. Team Mustang Girls’ first sponsor in the early days was SpeedDirect, who supplied us with a Steeroids rack-and-pinion system and Vector Series coilover front suspension.
We developed a relationship with Frankie Waters, a 12-year-old hot-rodder-in-training from Southern California who began writing the Frankie’s Garage column on Team Mustang Girls. At one point, Frankie asked us for recommendations on suspension and steering setups for her 1967 Mustang fastback, and of course the advice was to go with a Steeroids rack-and-pinion and coilovers. With Frankie and her parents, Tyler and Emily, only 50-odd miles from the TEN tech center in Santa Ana, California, we hatched the plan to surprise her one day with a suspension and steering setup donated by SpeedDirect, showing up at her house to present her with the news, and then loading up the car and bringing it to the shop for installation.
You can see it all unfold in the video here, but the short story is we put Frankie to work in our shop, installing the Steeroids rack-and-pinion and Vector Series coilovers with the help and advice from all of us.
The subject of course is a ’67 Mustang fastback with a warmed-over 460 under the hood, on which we installed the rack-and-pinion and coilovers. The Steeroids setup is totally bolt-on with no cutting or welding required (so if you ever want to return the car back to stock you can), and we got it installed in a day taking our time for photos and video.
The Vector Series coilovers are also a bolt-on but require two 5/16-inch holes to be drilled in the upper control arms (but the arms don’t need to be removed) for the lower coilover mount to attach. All of the parts and hardware needed for installation are included, including the power steering lines from the pump to the rack. For custom engine installations like Frankie’s 460 or a Coyote, you might have to alter the hose lengths and fittings, but SpeedDirect can make them based on your specs. So follow along as Frankie and Courtney take over a lift in the Tech Center and install the parts on Frankie’s car. This is going to be one hot high school ride for Frankie when she gets her driver’s license!
The Setup
Emily Waters photos
Frankie thought that we were in town to do a video of her and her Mustang for a Mustang Girl Monday piece for Mustang-360.com, but after a few minutes of walking around the car, we let her in on the surprise with the presentation of the parts, as SpeedDirect’s Kellie Colf came walking up to join the fun. Frankie was surprised to say the least (and even broke into tears), all of which you can see in the video on Mustang-360.com by the time this issue comes out. Check it out, it’s a good one!
From left to right are Kellie Colf of SpeedDirect, Frankie Waters, and Courtney Barber after the surprise.
We’re loading the ’67 Mustang onto our trick aluminum Jimglo trailer for its ride to the TEN Tech Center.
Here are all the parts and hardware included in the Steeroids rack-and-pinion and Vector Series coilover front suspension kits for early Mustangs. The rack-and-pinion steering will work with the stock steering column, but you will need to cut the end off to fit the U-joint supplied and then support the inner shaft with a retainer bearing. If you get the Steeroids kit with a steering column included, there is no cutting necessary. We used an ididit column in chrome.
The driver-side rack bracket bolts on like this, to existing holes in the frame.
Prior to installation on the car, the rack must have the urethane bushings and mounting brackets (included) installed on the ends. This is easier with a little spray lubricant (WD-40 is what we used) and a rubber mallet to tap the brackets into place.
Courtney lifted the rack into position while Frankie installed and tightened the mounting bolts.
This bracket bolts to the rack-and-pinion and locates the tie rods. This is the part of the rack that moves left and right during steering input.
One end of each tie rod attaches to the rack bracket and the other end to the steering arm on each spindle.
Always use antiseize on aluminum parts; especially the rod ends that thread into the steering rods. Be careful, antiseize gets everywhere. Courtney looked like the Tin Man from the Wizard of Oz after handling this stuff for two minutes!
A selection of bushings/spacers (the gold pieces in the photo) are supplied with the rack-and-pinion kit to get bumpsteer to zero degrees. Depending on the car’s ride height, control arms, spindle height, and other factors, these bushings can raise or lower the outward end of the tie rod so that it’s parallel with the lower control arm for minimum to zero bumpsteer. There are also aftermarket gauges that can be used to dial in bumpsteer if you want to do it yourself, or a competent alignment shop that knows muscle cars and/or aftermarket suspension parts can also get it perfect.
The rack-and-pinion installed. With the car in the air and the suspension at full droop, you can eyeball the toe-in to get it close, but the final setting must be done with the car on the ground, at full weight and ride height. Toe-in is set like any other car, by adjusting the steering rods in or out, then tightening the jam nuts on the rod ends.
The Steeroids kit comes with new high-pressure braided steel lines to hook to the power steering pump. The bottom line is a tight fit to the frame when getting it started but it does fit and clears once installed.
The column installs with an ididit dash bracket and also a firewall mounting plate with a bearing. Some adjustment must be made with the universal joints and rod that links the column to the rack in order for smooth, bind-free operation, so don’t tighten anything until it’s adjusted properly.
These U-joints and shaft are provided with the Steeriods kit to mate the column to the rack. Read the instructions when you put them together to get the proper U-joint phasing or you’ll encounter a bind in the linkage.
National Parts Depot (NPD) provided the Lecarra steering wheel and adjustable adapter that matches the chrome column. Frankie cried with delight at her new wheel.
Coilovers
With the rack-and-pinion installed, we turned to the SpeedDirect Vector Series coilovers. The kit comes with everything needed, including 10-way double-adjustable shocks, coil springs (specify the rate upon ordering), mounts, and spanner wrenches to adjust the ride height.
We can’t stress enough the importance of always reading the instructions! The coilovers are easy to install but there are things to be aware of when putting them together, like lubricating the roller bearing on the shock mount with antiseize to prevent galling.
The stock springs and perches must be removed (use a spring compressor, carefully), then the SpeedDirect bracket is loosely bolted to the stock perch boltholes to locate two 5/16-inch holes that must be drilled in the upper control arm.
With the bracket bolted to the upper control arm, the coilover slides up into the stock shock/spring tower.
This shows the bottom mount of the coilover. This is the driver-side, which was installed incorrectly by editor Kinnan and father Travis Waters. The Courtney-installed side was installed correctly! Note that the adjuster knobs for the shock are pointing inward—wrong! Don’t be stupid like they were.
The upper coilover mount uses the stock Mustang shock mount. Frankie’s car didn’t have them so we got a pair from NPD.
