Back to Article
8 of 29
A variable-displacement oil pump feeds oil from the aluminum pan in the exact volume and pressure needed for a given instance. "So the PCM sitting there and it's looking for an oil pressure at once. If it's hot out, it's going to command the displacement. We give it the oil pressure. If, you know, if somebody is running winter weight oil in the engine and they get a little too warm and springtime before they change it here, dial up its displacement a bit," Joel explained. "So you get the oil pressure and then the oil cooler is actually way oversized on the engine. So fundamentally the oil cooler set up in hot weather to cool and in cold weather, it's actually a heater. So it keeps the oil temperature normal operation right in the sweet spot."
