Dale Amy
July 1, 2009
Like most addictions, CDC's Flashback is not inexpensive, but, hey, you may as well put what's left of that shrinking 401k to good use. Who needs stocks when you can have something with the looks of a classic movie star, the moves of a world-class gymnast, the most modern of comforts and conveniences, and perhaps best of all, the blissful sonic qualities of a heavenly choir. A sound investment, in other words.
Mustang Snapshot
Body/Sheetmetal
*Dynacorn '67 Mustang fastback body shellCDC reinforced
Exterior
*CDC-designed front fascia with brake duct inlets
*Louvered hood with turn-signal lamps
*Sail panel close-outs
*Lower side scoops
*CDC-designed taillamps with integral back-up lamps
*AutoNik headlamps with integral LED turn-signals
*Scott Drake smoke-tinted door, vent, and rear backlite glass
*Sherwin Williams Planet Color Highland Green basecoat/clearcoat
*Applied by PSI Automotive Support Group
Engine
*Ford Racing Boss 347 crate engine M-6007-Z347
*450hp, 400 ft.lbs. torque
*Boss 4-bolt main block
*Forged crank, pistons, and rods
*"Z" aluminum heads with 1.65:1 roller rocker arms
*Hydraulic roller camshaft
*Dynatek Racing electronic fuel injection
*Vintage Air Front Runner accessory drive system
*Dyno results: 486.2hp @ 6,400 rpm; 438 lb.ft. of torque @ 5,200 rpm
Drivetrain
*Tremec TKO 600 5-speed transmission
*Ford Racing HD clutch kit
*Scott Drake clutch cable conversion kit
*DTS custom aluminum driveshaft
*RRS rearend housing
*Currie 9+ differential with 31-spline axles, Traction-Lok, and 3.70 gears
Exhaust
*Ford Powertain Applications stainless steel long-tube headers
*CDC-fabricated 2-inch stainless steel dual exhaust system
*CDC-designed quad exhaust tips
Steering
*RRS power rack-and-pinion
*Flaming River tilt steering column
Suspension
*RRS Phase 3
*Front independent
*Billet aluminum coilover struts with adjustable ride height
*Chrome silicone steel springs
*1-inch stabilizer bar
*RRS 3-link rear suspension
*Adjustable ride height
*Chrome silicone springs
*Watts link lateral stability control
Brakes
*Baer front discs
*14-inch slotted, drilled, and vented rotors
*6-piston calipers
*Baer rear discs
*6-piston calipers
*Bosch Hydroboost power brakes
*Drum-in-disc parking brake system
Wheels & Tires
*American Racing Torq Thrust II Series 405 wheels
*18 x 8 front
*18 x 9.5 rear
*Dunlop Direzza DZ 101 tires
*245/40R18 front
*275/35R18 rear
Interior
*CDC-designed front and rear seats
*Alea Leather seating surfaces
*Power driver's seat
*Folding rear seat system
*Leather-wrapped steering wheel
*Vinyl-wrapped trim panels
*Vinyl-wrapped console with cup holders and storage compartment*CDC-designed lowered seating*Increased headroom*Extended seat track for fore/aft adjustability*CDC dedicated vehicle build number nameplate on console*ACC black cut-pile carpeting*Aluminum pedal covers with dead pedal*Classic Instruments cluster with CDC-designed graphics*A1 Electric power windows, door locks, and keyless entry*Vintage Air Gen IV Magnum electronic HVAC system
Sound System
*Clarion radio head unit
*Rockford Fosgate amplification system
*4 coaxial speakers
*10-inch subwoofer
