February 1, 2008
Photos By: John Roper
Mufp_0802_12_z 1964_falcon_futura Mufp_0802_05_z 1964_falcon_futura Mufp_0802_06_z 1964_falcon_futura Mufp_0802_04_z 1964_falcon_futura Mufp_0802_10_z 1964_falcon_futura Mufp_0802_14_z 1964_falcon_futura Mufp_0802_15_z 1964_falcon_futura
For over-the-road cruising potential, Zach fitted his Falcon with a Tremec T-5 five-speed and Hurst shifter. We like what he did with the shifter boot-a custom-made leather-wrap design that ties in with the buckskin interior. Where most people would have gone with a 9-inch Ford rearend, Zach used an 8.8-inch late-model Mustang rear with 3.27 gears and a Traction-Lok. All it took was setting up the axlehousing with the appropriate leaf-spring mounts to get the correct pinion angle.
All in all, Zach built himself a nice road car that's ready for cruising and ready for racing, depending on his mood. As he begins to iron out the kinks and learn what works best, he'll come to enjoy the car even more and wind up with a ride to be envied anywhere he goes.
  • '64 Falcon Futura Hardtop
  • Owner: Zach Gerich, Ennis, TX
  • Engine
  • '89 5.0 small-block V-8
  • 4.000-inch bore
  • 3.000-inch stroke
  • Forged TRW flat-top pistons
  • 9.0:1 compression
  • Shotpeened and polished stock connecting rods
  • Ported 351W iron heads, 1.94/1.60-inch Manley stainless valves
  • 750-cfm Holley double-pumper
  • Edelbrock Victor Jr. single-plane high-rise
  • Ford Racing hydraulic roller camshaft (0.512/0.512 inch, 288/226 duration)
  • Comp Cams 1.6:1 roller rockers
  • Ford Racing 6.272-inch pushrods
  • Crane Cams 7/16-inch rocker studs
  • ATI ProCharger P600B centrifugal supercharger
  • Late-Model Ford alternator
  • Transmission
  • Tremec World Class T-5 five-speed
  • Hurst shifter
  • Rearend
  • 8.8-inch (from late-model Mustang)
  • 3.27 gears
  • Traction-Lok
  • Exhaust
  • Patriot shorty headers, 1-1/2-inch primaries, 2-1/2-inch collectors
  • Custom 2-1/2-inch dual exhaust
  • Flowmaster Series 40 two-chamber mufflers
  • Suspension
  • Front: Stock coil-on-upper arm, Shelby drop, KYB gas adjustable shocks
  • Rear: Stock leaf spring, Shelby underride traction bars
  • Brakes
  • Front: 10-1/2-inch disc
  • Rear:10-inch drum (late-model Mustang)
  • Wheels
  • Front: '01-'04 Ford Mustang "Bullitt" aluminum, 17x8-inch
  • Rear: '01-'04 Ford Mustang "Bullitt" aluminum, 17x8-inch
  • Tires
  • Front: Toyo Proxes4, P215/50ZR17
  • Rear: Toyo Proxes4, P215/50ZR17
  • Interior
  • Custom buckskin and sports vinyl, Grant steering wheel in {{{Dodge Magnum}}} Red, Kenwood amp with CD changer, Hurst shifter with custom leather wrap, Late Model Mustang accelerator pedal with cable, dashpad deleted
  • Exterior
  • Dodge Magnum Red paint by owner and father, recessed hood vents, shaved grille and trunk emblems
