Tech Editor, Mustang Monthly
November 23, 2006
Mufp_0612_27_z 1969_ford_mustang_sportsroof SuperchargerMufp_0612_28_z 1969_ford_mustang_sportsroof RadiatorMufp_0612_29_z 1969_ford_mustang_sportsroof Year_one_project_car_tagMufp_0612_34_z 1969_ford_mustang_sportsroof Roll_barMufp_0612_35_z 1969_ford_mustang_sportsroof Trunk
'69 Mustang SportsRoof
Owner: Bud Brutsman, Burbank, CA
Engine
'04 4.6 "Terminator" Cobra iron block
Forged steel crank
Steel H-beam rods
3.55-inch bore, 3.55-inch stroke
Aluminum heads
Four valves per cylinder, 37mm intake, 30mm exhaust
MSD DIS-4 coil-on-plug ignition
Custom throttle body mount
Custom Year One air-filter housing
Accufab throttle body
FAST XFI engine management with 60-lb/hr injectors
ARP fasteners
Canton oil pan
Moroso remote oil filter
Kenne Belle supercharger
Metco X-10 supercharger drive system
520 hp, 600 lb-ft of torque, tuned by MV Performance
Transmission
4R70W four-speed automatic overdrive, built by MV Performance, Statham, Georgia
Precision Industries 3,500-rpm stall converter
Be-Cool transmission cooler
Baumann Electronic Shift Controls, TCS Controller
Rearend
Currie 9-inch
Detroit Tru-Trac
3.90 gears
Exhaust
Custom built by Year One with Stainless Works components
Suspension
Front: Martz tubular front subframe, Martz spindles, Flaming River rack-and-pinion steering, Martz swaybar, QA1 10-400 springs, QA1 coilover shocksRear: Unique Performance rear suspension system, horizontally mounted QA1 coilover shocks, QA1 10-200 springs, torque arm, subframe connectors
Brakes
Front: Stainless Steel Brakes Force-10, 13-inch disc, Year One engraved calipers
Rear: Stainless Steel Brakes Force-10, 14-inch disc, Year One engraved calipersCustom hydroboost assist
Wheels
Front: Foose Design, 19x8
Rear: Foose Design, 20x10
Tires
Front: BFGoodrich G-Force T/A, P245/35ZR19
Rear: BFGoodrich G-Force T/A, P285/30ZR20
Interior
Cobra Misano black leather buckets, Year One gauge panel insert with Auto Meter Sport Comp gauges, custom console with '05 Mustang automatic shifter, Vintage Air heat/cool system, Alpine AM/FM/DVD audio system with navigation, Boston Acoustics amplifiers, component speakers, and subwoofers
Exterior
Black basecoat/clearcoat with satin black stripes, painted by Year One's Steve Jones; sheetmetal modifications including tucked bumpers, modified quarter-panel scoops, rocker extensions, custom front valance and hoodscoop performed by Year One's Kevin Gooch; exterior trim powdercoated black, final fit and finish performed by Jimmy Kerlin
