February 1, 2006
1971 Torino BroughamOwner: Bill Kulenkamp, Chelsea, MI
Engine
429ci Cobra Jet
4.360-inch bore, 3.590-inch stroke
370 hp, 450 lb-ft torque
Nodular-iron crank
Forged I-bBeam connecting rods
Cast pistons
Iron block and heads
715-cfm Rochester Quadrajet carburetion
11.5:1 compression
2.24/1.72-inch valves
Dual-point, dual-diaphragm distributor
Transmission
"Big-Shaft" Top Loader four-speed
Factory Hurst shifter
Rearend
9-inch
Traction-Lok
3.50 gears
28-spline axles
Exhaust
Factory dual exhaust
2-1/2-inch pipes
Suspension
Front:Coilover upper arm
Rear:Leaf spring
Brakes
Front:Disc
Rear:Drum
Wheels
Front:Magnum 500,15x7
Rear:Magnum 500,15x7
Tires
Front:Goodyear Polyglas GT biased-belted, F60x15
Rear:Goodyear Polyglas GT biased-belted, F60x15
Interior
Torino Brougham with bench seat
Horizontal Sweep Speedometer
Aftermarket Instruments
Exterior
Bright Red factory-original enamel
Torino Brougham trim package
