Steve Baur
May 24, 2012
"It wasn't what I wanted to see," say David, "but sentimental value kicked in and I bought it for $3,200." With his old car in his possession now, David was ready to pull the trigger on a full restoration, but not a year later, David found out that his wife was pregnant with their first child. A new lifestyle change and money direction was put into effect, and the fastback would remain dormant for more than 20 years before the promised restoration began. The couple traded the '84 GT for an Aerostar mini-van, and it would be some time before David heard the familiar rumble of a V-8.
Once underway in 2004, the Mustang's restoration took just over a year. The slick, black beauty was repainted, the interior was restored to its original bright white tone, and the drivetrain was upgraded with a modern powerplant with a healthy 405 flywheel horsepower. David did most of the work himself, aside from farming out the body- and paintwork, and getting some help from Josh LeBlanc in assembling the Keith Craft stroker small-block. Backing the stout mill is an overdrive five-speed transmission that allows for highway cruising to his Ford-Mustang club of Acadiana meetings, or various car shows where David's Mustang has garnered its fair share of trophies. All it took was a chance call to make it happen, and some patience, perseverance, money, and persistence.
David Dore's '65 Mustang Fastback
Engine
  • Ford 5.0L block, 331ci short-block built by Keith Craft Performance Engines (Arkadelphia, Arkansas)
  • 4.030-inch bore
  • 3.250-inch stroke
  • Eagle forged steel crankshaft, Scat forged I-beam connecting rods, SRP forged aluminum pistons
  • Keith Craft custom hydraulic roller camshaft
  • 0.513-inch lift, 224/230-degree duration at 0.050-inch lift
  • Airflow Research 185cc aluminum cylinder heads
  • 2.02-inch intake, 1.60-inch exhaust valves
  • Edelbrock Performer RPM Air Gap intake manifold
  • Holley 650-cfm carburetor
  • Pertronix III ignition
  • 10:1 compression ratio
  • 405 hp, 411 lb-ft of torque at the flywheel
Transmission
  • Ford Racing Performance Parts T-5 five-speed manual
  • Ram clutch and flywheel
Rearend
  • Ford 8-inch housing
  • Traction-Lok differential
  • 3.50 gears
Exhaust
  • Doug's Headers long-tube headers, 1 5/8-inch primaries
  • National Parts Depot exhaust with H-pipe and turbo mufflers, Jet-Hot coated
Suspension
  • Front: Mustangs Plus Grab-A-Trak front coils and shocks, manual steering
  • Rear: Mustangs Plus Grab-A-Trak leaf springs and shocks, Grab-A-Trak Under Rider traction bars
Brakes
  • Front: 11-inch disc, single-piston calipers
  • Rear: Factory drum
Wheels
  • Front: Custom Wheels Market Bullitt Style, 17x8, 4.25-inch backspacing
  • Rear: Custom Wheels Market Bullitt Style, 17x8, 4.25-inch backspacing
Tires
  • Front: Hankook Ventus HRII, P235/45R17
  • Rear: Hankook Ventus HRII, P235/45R17
Interior
  • TMI White Deluxe Pony interior, Custom Auto Sound head unit, center console, Rally-Pac
Exterior
  • Dupont Black basecoat/clearcoat, bodywork by Mace Maniscalco, paint by Lance Thibodeaux
