Tech Editor, Mustang Monthly
June 21, 2010
While the bodywork and styling exercise efforts are easy to see, what's not easy to see without opening the hood or getting on your hands and knees is the suspension and driveline that motivate the delivery and keep its shiny side up. For starters, the delivery wasn't going to be powered by some basic 5.0L swap, or even a built Windsor. No, Merv wanted people to stop and stare when the hood went up, and people certainly do when they spot the 514ci stroker that was built by Jon Barrett's Hot Rod Shop. Based off of a 385-series 460 casting, the engine was stuffed with a nodular iron stroker crank and forged rods and pistons and then topped with Edelbrock induction and a Holley 870cfm Street Avenger carburetor. To fit the big-block, a Heidts Mustang II frontend was welded into place and then reinforced for the weight of the big-block. With the shock towers in the scrap pile there was plenty of room for the big-block to reside and the Sanderson block-hugger headers help even more. The rest of the drivetrain consists of a Performance Automatic Competition AOD four-speed automatic with a 2,500 rpm stall converter spinning an aluminum driveshaft from Mustangs Plus, and a narrowed Currie 9-inch with 3.50 gears. Stainless Steel Brakes discs at all four corners help with the "whoa power" and are wrapped in Wheel Vintiques polished 17-inch wheels and Nitto rubber.
If you thought the metalwork needed to create such a vehicle was a head scratcher, then you have to realize the interior wasn't any easier. Sure, from the front seats forward it's still all Mustang, and the M-Detail Flo Fit seats, Dakota Digital Gauges, Lokar shifter and more all pretty much bolted in without any fuss. But look rearward and you've got another problem. With the framerails moved inward, which of course moved the wheelhouse inward, the fold-down seat assembly had to be cut down to size and custom upholstery made for it. Same goes for the extended length custom headliner all the way to the rear hatch. While the stock fiberglass side panels worked up front, to finish off the side walls of the delivery a second set of original panels were trimmed down and reversed to fit at the back of the load floor. Extra bulk carpet from Auto Custom Carpets was ordered to finish off said area as well.
Since the sedan delivery has been complete, it has been getting lots of attention at shows that include the MCA 30th anniversary bash and many others. Merv is always ready for the deluge of questions, with many looking at the craftsmanship and wondering if it's a factory piece they've just never known about. True, it's not everyone's cup of tea, but that's what makes this hobby so great-that we can build whatever we want that makes us happy every time we get in it and twist the key, and what other people think shouldn't matter. As for Merv, well, he has some deliveries to make and more cars to build, including a mid- or rear-engine-powered Mustang he's been dreaming of for several years.
Merv Rego's '66 Mustang Sedan Delivery
Engine
  • 514ci 460 big-block-based stroker
  • Assembled by Jon Barrett Hot Rod Engines
  • 4.440-inch bore
  • 4.150-inch stroke
  • Nodular iron crankshaft
  • Eagle 4130 forged I-beam rods
  • Probe forged pistons
  • Total Seal rings
  • Clevite bearings
  • Comp Cams flat tapped hydraulic cam
  • Comp Cams Pro Magnum roller rockers
  • Edelbrock Cobra Jet aluminum cylinder heads
  • Edelbrock Victor Jr. single-plane intake manifold
  • Holley 870cfm Street Avenger carburetor
  • MSD Pro Billet ready to run distributor
  • MSD plug wires
  • Edelbrock Victor Series water pump
  • Saldana Racing aluminum radiator
  • Flex-a-lite twin fan system
  • PA Performance PMGR starter
  • March Performance serpentine beltdrive kit
  • Tuff Stuff Performance Products alternator and power steering pump
  • ARP internal engine fasteners
  • Totally Stainless external fasteners
Transmission
  • Performance Automatic Competition AOD
  • 2,500 rpm stall speed 10-inch Pro Launch converter
  • Mustangs Plus aluminum driveshaft
Rearend
  • Currie 9-inch housing, narrowed 4 inches
  • Traction-Lok differential
  • 31-spline axles
  • 3.50 gears
Exhaust
  • Sanderson Street Rod block-hugger headers, 1 7/8-inch primary, 3 1/2-inch collector
  • Bassani universal street rod exhaust kit, 2 1/2-inch tubing, X-crossover insert
  • Bassani Quiet Thunder mufflers
Suspension
  • Front: Heidts Mustang II, power rack-and-pinion steering, Heidts power steering control valve
  • Rear: Eaton Detroit Spring five-leaf mid-eye springs, KYB Gas-a-Just shocks
Brakes
  • Front: Stainless Steel Brakes Force 10 disc, 11-inch slotted rotor, four-piston caliper
  • Rear: Stainless Steel Brakes Force 10 disc, 10.5-inch slotted rotor, single-piston caliper
Wheels
  • Front: Wheel Vintiques polished Bullet 105 Series, 17x8, 5 1/2-inch offset
  • Rear: Wheel Vintiques polished Bullet 105 Series, 17x9 1/2, 5-inch offset
Tires
  • Front: Nitto NT555 Extreme, P245/45R17
  • Rear: Nitto NT 555 Extreme, P275/40R17
Interior
  • M-Detail Flo Fit high-back seats with Pony interior inserts, Auto Custom Carpets dark tan carpet set and bulk carpet for load floor, LeCarra steering wheel on Flaming River tilt column, Custom Autosound head unit, 4-inch dash speakers, power windows using window cranks for switches, power locks, Dakota Digital instrumentation, Lokar shifter and parking brake, Lokar pedal pads, illuminated doorsill plates, Hot Rod Air Elite heat and A/C system
Exterior
  • Custom mix purple metallic PPG basecoat/clearcoat, fiberglass Shelby front valance from Tony Branda Performance, fiberglass hood from Mustangs Plus, Mustang Depot billet grille, Scott Drake billet taillight bezels and gas cap, GT rear valance, '71 Mustang door handles, Tri-bar headlamps
