Tech Editor, Mustang Monthly
April 1, 2010
With the body mods and paint in check, Classic Restorations turned its efforts to the SportsRoof's suspension. Heidt's products are used at all four corners, but just like the rest of the build, the Heidt's stuff didn't stay stock. The front Mustang II setup was installed higher than the instructions state for a lower stance while the rear four-link kit utilizes custom-fabbed frame brackets and Panhard bar to allow the huge rear tires to clear. Wilwood binders got the nod front and rear for stopping power while a 9-inch rear with a 3.70-geared Auburn and a Tremec TKO-600 back up the Ford Racing crate engine Mark provided. Budnik GTX wheels, 18s up front and 20s out back, finish off the suspension upgrades and give the custom red paint some much needed contrast with their powdercoated gray centers.
For the interior, Classic Restorations had Cutter's Custom Stichin' in nearby Dillsboro, Indiana, do what it does best with a combinat-ion of dark charcoal leather, wool carpet, and stainless steel mesh in what must be one of the most interesting Mustang interiors we've seen in quite a while. Modified SCAT seating and a matching Budnik GTX steering wheel are joined by a Custom Autosound Secret Audio system, a JME gauge cluster in a modified dash that leads into a custom console and rear seat setup, while power windows and a Vintage Air A/C and heat round out the interior. Even the trunk is fully dressed in a cow's hide worth of leather, more stainless mesh, and wool carpeting.
With the completion of the SportsRoof, Pat and Dustin wanted to put a few miles on the car before delivering it to Mark and that's where we met up with the crew of Classic Restorations during the NMRA finals in Bowling Green, Kentucky, last year. Before Mark took delivery of the car, Classic Restorations had taken a couple of awards with it, including four different Goodguys events awards, a Best of Show at Bowler's Day at the Strip show, and Director's Choice at the NMRA World Finals. It's not every day that you can take delivery of a fresh Mustang build and have it come with a trunk full of awards too. Now Mark has two fresh SportsRoofs to start building many more years of Mustang Memories.
Mark Jacobi's '70 Mustang SportsRoof
Engine
Ford Racing 460ci big-block crate engine
Ford Racing 460 Super Cobra Jet aluminum cylinder heads
Hydraulic flat tappet cam, 0.588/0.614 lift, 244/254 degrees duration at 0.050-inch
Edelbrock Victor intake
Barry Grant Demon 850cfm
MSD distributor
MSD 6AL ignition
MSD 8mm ignition wires
K&N air filter in custom, hand-fabricated sheetmetal air cleaner
10.5:1 compression ratio
550hp at 6,250 rpm
600 lb-ft at 4,750 rpm
Transmission
Tremec TKO-600 by Bowler Performance
Hurst shifter
Rearend
9-inch nodular
Auburn Pro differential
3.70 gears
31-spline axles
Exhaust
Classic Restorations built 17/8-inch long-tube headers
3-inch collectors
Stainless band clamps
3-inch Flowmaster DeltaForce Race 40 Series mufflers
Suspension
Front:
Heidt's Mustang II crossmember, QA1 coilovers, power rack-and-pinion
Rear: Heidt's four-link, QA1 coilovers
Brakes
Front:
Wilwood disc, 12-inch drilled and slotted rotor, polished caliper
Rear: Wilwood disc, 12-inch drilled and slotted rotor, polished caliper with internal parking brake
Wheels
Front:
Budnik GTX, gray powdercoated center, polished lip, 18x8
Rear: Budnik GTX, gray powdercoated center, polished lip, 20x10
Tires
Front:
BFGoodrich G-Force T/A, P245/40R18
Rear: BFGoodrich G-Force T/A, P295/40R20
Interior
Charcoal gray leather seating surfaces, door panels, console, and headliner; charcoal gray wool carpet; stainless steel mesh accents by Cutter's Custom Stitchin' of Dillsboro, Indiana; gray powdercoated Budnik GTX steering wheel; modified SCAT seats; JME Enterprises gauge cluster painted to match interior; Auto Meter gauges; Custom Autosound Secret Audio system; 6-inch speakers in kick panels; 6x9 speakers in rear seat panels; trunk-mounted 10-disc CD changer; lower half of dash custom fabricated; custom console and rear seat; New Relic power windows; Vintage Air A/C and heat system; recessed A/C vents in lower dash panel; electric trunk release; custom billet quarter-panel vents in door openings
Exterior
PPG Concept Classic Resto Red custom mixed paint, custom fiberglass hoodscoop, custom fiberglass front spoiler, front and rear bumpers tucked tight to body, shaved side marker lights, trunk lock, and emblems, recessed LeMans fuel cap, molded front and rear fender extensions, welded rear valance, rear fender openings stretched 1 inch, bottom of hood smoothed, recessed taillights, rear wheel housings tubbed, recessed rear license plate, body underside coated in color-matched truck bed liner
