Wayne Cook
February 1, 2009
Photos By: Jeff Creech
Larry and Phyliss Hamm's '08 Roush P-51A Mustang
Number 23 of 151 built
To achieve the higher 510hp rating, Roush goes into the 4.6L 24-valve engine and upgrades the reciprocating assembly. The stout new equipment includes a forged steel eight-bolt crankshaft, forged aluminum pistons with increased dish to lower the compression from 9.8:1 to 8.6:1, and forged steel H-Beam connecting rods. The lower compression ratio allows for extra boost pressure. The extra strength components, Eaton TVS 2300 supercharger, and high-capacity air-to-water intercooler support the 510hp rating. Compared to the Blackjack, the P-51A also has bigger injectors and larger induction.
Engine
  • 4.6L SOHC three-valve V-8
  • 281 ci
  • 3.55-inch bore
  • 3.54-inch stroke
  • Forged steel crank
  • Forged H-beam rods
  • Forged pistons
  • 8.6:1 compression
  • RoushCharger (Eaton TVS 2300 supercharger)
  • Dual 60mm throttle body
  • Special fuel rails
  • 52 lb/hr injectors
  • 510 hp
  • 510 lb-ft torque
Transmission
  • Tremec five-speed manual
  • Short-throw shifter
Rearend
  • 8.8-inch
  • 3.55 gears
Exhaust
  • Roush off-road exhaust system
Suspension
  • Front: Roush Stage III Suspension including front struts, replacement springs, antisway bar, strut tower brace
  • Rear: Roush Stage III Suspension including shocks, springs, antisway bar, and pinion snubber
  • Roush wheelhop reduction kit
Brakes
  • Front: 14-inch two-piece rotors, four-piston calipers
  • Rear: OE disc with calipers painted to match the front
Wheels
  • Roush forged chrome, 18 by 10
Tires
  • BFGoodrich g-Force T/A KDW, P275/40ZR18
Interior
  • Custom Roush Leather Sport Bucket Seats with P-51A logo, aluminum accessory upgrade, Auto Meter three-gauge pod, custom 400-watt DVD Stereo with navigation
Exterior
  • Metallic Silver paint, Olive Drab hood stripe, Roush four-piece body kit, LED taillights and rear brake light, headlight splitters, Lambo Style Doors by LSD, painted Mirror Covers
