Eric English
July 1, 2008
Mdmp_0807_09_z 1964_ford_falcon EngineMdmp_0807_10_z 1964_ford_falcon EmblemMdmp_0807_11_z 1964_ford_falcon FrontviewMdmp_0807_12_z 1964_ford_falcon Front_sideMdmp_0807_13_z 1964_ford_falcon Engine2Mdmp_0807_14_z 1964_ford_falcon Under_hood
All-Rounder
When installation of all the performance hardware was wrapped up, the Boettchers found themselves with a car that is more than worthy of the speedy Falcon name, and carries on in the fine performance tradition of the '64/'65 body style. It's not over the top in any one area, yet it's a capable achiever in multiple disciplines. First and foremost, Jeff and Kevin agree that the project promoted quality time together and a stronger family bond-no doubt the best attribute of the car we can relay to our readers. Beyond that, Jeff's '64 is a terrific cruiser, energetic street performer, and occasional show participant.
It's also abundantly clear that the need for speed continues to grow in both Jeff and Kevin, as without prompting, they described plans for testing the Falcon's supercharged mettle on the dragstrip. Sounds like the Boettcher house had best prepare for a new round of that speed bug.
Jeff Boettcher's '64 Falcon
Engine
  • 331ci stroker short-block by Mike's Mustangs, Marysville, Washington
  • AFR 185 cylinder heads, 2.02/1.60-inch stainless valves
  • 1.6 roller rockers
  • Ford Racing Performance Parts E303 hydraulic-roller camshaft
  • Edelbrock Performer intake
  • Blower-spec Demon 670 carburetor
  • MSD ignition
  • MSD distributor
  • Paxton Novi 1200 supercharger
Transmission
  • Ford AOD
  • 2,700-rpm torque converter
  • B&M shift-improvement kit
  • B&M shifter
  • Lokar shifter cables
Rearend
  • Currie built 9-inch
  • 3.89 gears
  • Traction-Lok differential
  • 31-spline axles
Exhaust
  • Custom shorty headers, metallic ceramic coated
  • 3-inch x-style crossover
  • Flowmaster mufflers
  • Mandrel-bent dual exhaust
Suspension
  • Front: Total Control upper and lower front control arms, Total Control strut rods, VariShock coilovers, Total Control rack and pinion steering, Addco 1-inch sway bar, custom shock tower bracing
  • Rear: four leaf springs, KYB shocks, subframe connectors
Brakes
  • Front: Stainless Steel Brakes 11-inch disc
  • Rear: Stainless Steel Brakes 11-inch disc
Wheels
  • Front: Kinesis 3-piece, 17x7, custom offset
  • Rear: Kinesis 3-piece, 17x8, custom offset
Tires
  • Front: BFGoodrich g-Force T/A KD, P205/50ZR17
  • Rear: BFGoodrich g-Force T/A KD, P225/45ZR17
Interior
  • Cerullo XR leather buckets, B&M shifter, Auto Meter gauges, Pioneer CD player w/trunk-mounted changer, Kenwood amps, Infinity speakers, MTX 12-inch subwoofer
Exterior
  • Wimbledon White, painted by Moslander's Rod and Custom, Monroe, Washington
