October 30, 2012
Photos By: Drew Phillips
'86 GT
Engine and Drivetrain
Block Stock
Crankshaft Stock
Rods Stock
Pistons Hypereutectic, 0.030 over
Camshaft Comp Cams Xtreme Energy XE270HR
Cylinder Heads Edelbrock Performer with 1.90/1.60 valves, and Crane Cams ‘94 Cobra roller rockers
Intake Manifold Trick Flow Street Heat w/ 70mm throttle body
Fuel System 155-lph fuel pump w/ billet fuel rails, an adjustable pressure regulator, and stock injectors
Exhaust BBK Performance short-tube headers w/ a Bassani X-shape crossover pipe and a Magnaflow after-cat exhaust
Transmission Stock T5 w/ a Ford Racing King Cobra clutch, a Hurst shifter, and a Ford Racing aluminum driveshaft
Rearend 8.8 w/ stock axles, stock differential, and 3.55 gears
Electronics
Engine Management Stock '89 mass air computer w/ a DiabloSport chip and a custom AMP tune
Ignition Stock w/ MSD coil, Ford Racing spark plug wires, and Champion spark plugs
Gauges Stock
Suspension and Chassis
Front Suspension
K-Member AJE Racing tubular
A-Arms AJE Racing tubular
Struts Tokico w/ Steeda Autosports caster/camber plates
Springs Coilover
Brakes Stock w/ Raybestos brake pads
Wheels Shelby GT500 replica, 17x9-in
Tires BFG Sport T/A
Rear Suspension
Shocks Tokico
Springs Steeda Autosports
Control Arms Stock
Brakes Stock
Tires BFG Sport T/A
