Back to Article
7 of 9
Not your average Four-Valve, Adam's '98 Cobra makes use of an '04 Cobra engine and transmission. Thanks to a Hobbs switch, when boost exceeds 5 pounds--which hopefully is quite often--the 255-lph inline fuel pump supplies the necessary fuel to the 60-lb/hr injectors. As you can see, it's not all go under the hood. The supercharger, Dragon plenum, and cam covers were treated to a few coats of Bright Atlantic Blue, as well.
