Steve Turner
September 2, 2011
Photos By: Ryan Merrill
"It has always been a dream of mine to own a Shelby. I've always been a fan of Shelbys and the racing heritage. But the biggest reason I like to racing my Shelby GT500 is that it's hard to make it go fast. It's a heavy car and it doesn't have the best aero..." Chris explained. "You don't see too many true Super Snakes trying to do it either. The list for 200-mph GT500s is really short, and I hope I can add to that small list one day. The car was just built, so we are still learning herùonce we do some tweaking, she'll be over 200 on even a bad day."
Over 200 mph sounds like a great day, but that's just the beginning of Chris' goals. "Once we eclipse 200 mph in the standing mile, we'll likely step up the game and go for a higher speed," Chris added. "Maybe next time we'll shoot for 225. 5.0
Horse Sense: Revan Racing (www.revanracing.com) obviously knows its way around a GT500, and the company is nearly synonymous with the dual-fan heat exchanger and large radiator it co-developed with C&R Racing. These days the '07-'11 Shelby GT500 Dual Pass/Dual Puller Fan Air to Water Heat Exchanger Kits and '07-'11 Shelby GT500 High-Capacity Radiator are blessed by the man himself and wear the official Shelby logo.
Engine and Drivetrain
Block Ford GT aluminum wet-sump
Crankshaft Double-keyed forged
Rods Oliver
Pistons L&M Engines custom w/Speed Pro rings
Camshafts L&M Engines custom
Cylinder Heads Stock, ported by Fox Lake Power Products
Intake Manifold Stock
Power Adder Kenne Bell 3.6LC w/3.6-in pulley, Kenne Bell twin 75mm throttle body, polished 5-in inlet, and Revan Racing dual-fan heat exchanger
Fuel System Three Walbro GSS342 pumps w/braided lines, Fore Precision fuel rails, Fore Precision fuel pressure regulator, and 166-lb/hr fuel injectors
Exhaust Amercian Racing Headers 2-in long-tubes w/Borla mufflers
Transmission FRPP Boss R1 six-speed manual w/SPEC clutch and Dynotech driveshaft
Rearend 9-in w/3.00 gears
Electronics
Engine Management Stock w/Lund Racing tune
Ignition Stock
Gauges Stock w/Aeroforce and Dashdaq
Chassis and Suspension
Front Suspension
K-member BMR with 1/2-in engine lowering
Control Arms BMR
Struts Stock Super Snake
Springs Eibach
Brakes Shelby/Baer w/Baer HTC pads
Wheels 21-in HRE Comp C93
Tires Toyo Proxes R888
Rear Suspension
Control Arms Griggs Racing double-adjustable
Shocks Stock Super Snake
Springs Eibach
Brakes Shelby/Baer
