Sharad Raldiris
August 28, 2011
Engine and Drivetrain
Block Iron Explorer block
Crank Eagle forged stroker crankshaft
Rods Manley H-beam connecting rods
Pistons Ross forged pistons, 8.5:1 compression ratio
Cams Stock Three-Valve
Cylinder Heads Stock, ported by Fox Lake Racing
Intake Manifold Whipple intercooled lower manifold w/custom upper manifold
Throttle Body Whipple billet mono-blade
Mass Air 95mm Sniper
Power Adder Mustang Motorsports turbo system w/Turbonetics 82mm ball-bearing turbocharger, Precision Turbo 64mm wastegate, ProCharger Race bypass, air-to-water intercooler, and HKS EVC boost controller
Fuel System Stock tank, Triple Ford GT pumps Fore Precision hat, Zone 5 fuel-pump driver, -8 fuel line, Metco fuel rails, and FRPP 80-lb/hr injectors
Exhaust Custom hot-side turbo piping w/Borla Catback system
Transmission Lentech 4R70W w/transbrake; 9.5-in, 3,500-stall-speed Lentech torque converter; FRPP driveshaft; and BMR driveshaft loop
Rearend 8.8-in w/33-spline Moser axles, C-clip eliminators, spool, FRPP 3.55 gear, and FRPP girdle
Electronics
Engine management Spanish Oak with Sniper tuning by Mustang Motorsports
Gauges Speed of Sound A-pillar mount w/Auto Meter Cobalt water temp, trans temp, and oil pressure gauges; Auto Meter dash pod with Auto Meter Cobalt boost and fuel pressure gauges; AEM wideband air/fuel meter; and Auto Meter shift light
Chassis and Suspension
Front Suspension
K-member BMR w/tubular radiator support
Struts Stock
Springs UPR Drag Launch by Eibach
Brakes Stock w/drilled and slotted rotors
Wheels 17x4.5-in Race Star DragStar
Tires 185/55-17 M&H
Rear Suspension
Control Arms UPR Pro Series system with relocation brackets and double-adjustable Panhard bar
Shocks Stock
Wheels 15x10-in Race Star Dragstar
Tires 325/50-15 Mickey Thompson ET Street Radials
Chassis Stiffening Maximum Motorsports six-point rollbar with RCI harnesses
