Michael Johnson
August 23, 2011
The build also inspired Wes and a few buddies to start the website www.hpmustangs.com. "We felt the need to share some hard-learned lessons and to enhance this great hobby," Wes says. The site allows fellow Mustang enthusiasts to share ideas, plan future events, but most of all keep people motivated to enjoy "what this hobby is about," Wes explained.
Engine and Drivetrain
Block Stock
Crank '03-'04 Cobra
Rods Manley Performance
Pistons Manley Performance
Camshafts Modular Powerhouse blower grinds
Cylinder Heads Stock w/Modular Powerhouse Stage 2.5 port
Intake Manifold Stock Bullitt
Throttle Body Stock Bullitt
Mass Air PMAS blow-through
Power Adder Vortech YSi supercharger w/3-in pulley, X02 intercooler, ProCharger Red Race bypass valve, 4-in intake pipe, eight-rib accessory drive, and Innovators West overdrive dampener
Fuel System Glenn's Performance sumped fuel tank w/ MagnaFuel Pro Tuner 750 fuel pump, Aeroquip -10 supply, -8 return lines, Fore Precision Works fuel rails, FRPP 80-lb/hr injectors, and MagnaFuel 1:1 boost-referenced fuel-pressure regulator
Exhaust Hooker Super Comp long-tube headers w/matching H-pipe, and Bassani Xhaust after-cat exhaust
Transmission Rockland Standard Gear Tranzilla T-56 six-speed w/SPEC Stage 3+ clutch and steel flywheel, Steeda Autosports Tri-Ax shifter, and '04 Cobra aluminum driveshaft
Rearend Factory 8.8 w/Eaton differential, 3.73 gears, and Strange Engineering 31-spline axles
Electronics
Engine management Stock computer w/SCT X-Cal2-tuned
Gauges Stock, w/Auto Meter Phantom series water, boost, and fuel pressure; Innovate Motorsports air/fuel monitor; and Raptor shift light
Chassis and Suspension
Front Suspension
K-member UPR Products tubular
Struts Stock Bullitt
Springs Eibach coilover 250 in-lb
Caster/Camber Maximum Motorsports
Brakes Stock w/Hawk HPS pads
Wheels 18x9-in chrome Saleen replicas
Tires BFG g-Force TA KDW 265/35-18
Rear Suspension
Shocks QA1 12-way adjustable
Springs Eibach 175 in-lb coilovers
Control Arms Wolfe Racecraft double-adjustable uppers and lowers
Brakes Stock, Hawk HPS pads
Wheels 18x10-in chrome Saleen replicas
Tires BFG g-Force TA drag radial 295/35-18
Chassis Stiffening Maximum Motorsports full-length subframe connectors
