Dale Amy
September 27, 2010
'06 Saleen S281
Engine And Drivetrain
Block 5.4-liter F-150 Lightning
Bore Stock
Stroke Stock
Displacement 330 ci
Crankshaft Stock Lightning
Rods Oliver billet
Pistons JE
Compression Ratio 8.5:1
Camshafts Stock Terminator
Heads Terminator Cobra, Fox Lake Stage 3 porting
Intake Hogan sheetmetal
Power Adder Precision Turbo 76mm billet, plus Speedtech Nitrous 125 shot
Throttle Body 80mm BBK (for 5.4 F-150)
Mass Air PMAS
Injectors Precision Turbo 65-lb/hr
Fuel Pump Fore Precision Ford GT triple-pump hat, Y-block, MDM driver
Headers Custom, AMP Performance
Exhaust Custom, AMP Performance
Transmission Tremec TR-6060
Clutch McLeod twin-disc
Rearend 8.8 w/FRPP 4.10 gearset and Auburn Pro diff
Electronics
Engine Management Stock, with Delta Force tune
Ignition Delta Force coils
Gauges Saleen
Suspension and Chassis
Front Suspension
K-member Stock
Control arms Stock Springs
Eibach Multi-Pro R2 coilover
Struts Eibach Multi-Pro R2 coilover
Sway bar Steeda
Brakes Stock Saleen
Wheels Custom Giovanna GFG, 20x9.5-in
Tires Nitto 555R, 275/35R-20
Rear Suspension
Springs Eibach Multi-Pro R2 coilover
Shocks Eibach Multi-Pro R2 coilover
Control arms FRRP billet upper and lower arms
Sway bar Steeda
Brakes Baer 13-in rotors
Wheels Custom Giovanna GFG, 20x11-in
Tires Nitto 555R, 295/35R-20
