Roger C. Johnson
August 3, 2010
Photos By: Steve Turner
These cars utilize the bedrock theory to ensure strength and long-life. But this bedrock is comprised of Manley racing pistons, Manley H-beam connecting rods, a forged-steel crank, ported aluminum heads with three-angle valve job, and ARP fasteners. Every other engine component was selected for its inherent strength and inclination to laugh at abuse. Be Cool radiators, Metco pulleys, SFI dampers, twin Precision turbos and twin aluminum air-water-air intercoolers in conjunction with an oversized AFCO heat exchanger set the stage. The blown version utilizes a Whipple twin-screw supercharger and a 5-inch aluminum intercooler. SPO was tapped for stainless steel exhaust components.
Exterior design for all three cars is aggressive and distinct. Front and rear fascias are restyled specifically for these models. A front carbon-fiber air splitter leads the way for upper and lower billet grilles, front brake-cooling ducts, fender flares, and side exhaust skirts. Quarter window scoops and trim-line side-view mirrors further improve aerodynamic continuity. Rear air diffusers and a Pro Stock rear wing round out, or smooth out, the visual tricks. Magnum Collision Repair Center takes credit for the incredible paintwork on these machines.
With the unique paint and bodywork of the Platt & Payne 'Stang, odds are you won't see yourself on the other side of the road. It's more likely you'll see plenty of competitors in your rear-view mirror-just like Hubert and Randy did.
The Boss Option
The newest addition to the Shadrach program is a Signature Edition Boss 429 drivetrain option. To maintain this particular machine's exclusivity, only seven examples of "The Boss" Signature Edition will be built on a first-come, first-serve basis. For those not lucky to get one of these seven fully optioned "The Boss" Shadrach Mustangs, Pure Power Motorsports offers all the components for the discriminating enthusiast to option their own "Shadrach," and have it built by either Pure Power Motorsports or an assembler of their choice.
This Boss 429 offering is methodically designed around a complete plug-in package. Included is the required bracketry to allow all standard factory accessories to operate correctly, making this system the only one of its kind in the industry. Depending on the customer's desires, the Boss 429 can be configured to displace 600 to 900 ci, with power ratings ranging from 800 to over 1,500 hp. These fabulous examples of civil disobedience come with a three-month, 3,000-mile warranty.
'05 Platt & Payne Signature Edition
Engine and Drivetrain
Block Ford 4.6 aluminum block
Bore 3.552 in
Stroke 3.543 in
Displacement 281 cid
Crankshaft Ford Racing Performance Parts forged
Rods Manley H-beam
Pistons Manley forged
Camshafts Stock
Heads Ford ported and polished aluminum with three-angle valve job
Intake Kinsler eight-stack
Power Adder Twin Precision turbos
Wastegates Tial, low boost, 11 psi; high boost, 19 psi
Blow-off Valves Tial
Throttle Body Kinsler
Injectors Primary: Ford 28-lb/hr Secondary: Bosch 65-lb/hr
Fuel Pump FRPP
Headers Pure Power Motorsports custom w/1 3/4-inch primaries
Exhaust SPO stainless steel
Transmission G-Force six-speed
Rearend Ford 9-inch with Strange axles
Electronics
Engine Management DiabloSport Predator
Ignition Ford ECU with Diablo tune
Gauges Defi Heads-up gauge display
Chassis and Suspension
Front Suspension
Springs Hyperco
Struts Ohlin double-adjustable
Brakes Brembo 14-inch
Wheels 20x9 PPM custom Weld Racing
Tires Pirelli P-Zero 255/35R
Rear Suspension
Springs Hyperco
Shocks Ohlin double-adjustable
Control Arms AJE tubular
Brakes Brembo 13-inch
Wheels 20x12 PPM Weld Racing
Tires Pirelli P-Zero 315/35R
