May 21, 2010
1992 Mustang LX
Engine and Drivetrain
Block 2001 4.6
Displacement 281ci
Crankshaft Stock
Rods Stock
Pistons Stock
Camshafts Stock
Cylinder Heads Stock Two-Valve
Intake Manifold Roush
Throttle Body BBK 75mm
Mass Air Lightning 90mm, JLT Performance cold air
Power Adder Roush M90 supercharger, Metco Motorsports 2.57-inch pulley, 10 pounds of boost, '03 Cobra heat exchanger and Rigid Race Cars battery tray-mounted expansion tank
Fuel System Glenn's Performance Sleeper fuel tank, Aeromotive A1000 fuel pump and regulator, Aeroquip fuel lines, UPR Products fuel rails, Roush fuel injectors
Exhaust Rigid Race Cars-modified MAC long-tube headers and Pro-Chamber intermediate pipe, Flowmaster two-chamber mufflers
Transmission Tremec TKO 500, SPEC Stage 3+ clutch, Roush aluminum flywheel, Pro-5.0 shifter, Ford Racing Performance Parts aluminum driveshaft
Rearend 8.8 with 9-inch ends, Eaton Posi, 3.73 gears, Strange Engineering 31-spline axles, MAC stud girdle
Electronics
Engine Management '01 Bullitt computer, SCT X-Cal III tune, FAST air/fuel meter
Ignition Stock, NGK spark plugs
Gauges Auto Meter Ultra-Lite tachometer, oil, water, volts, and boost
Chassis and Suspension
Front Suspension
K-member Anthony Jones Engineering "Mod-swap" tubular
Control Arms Stock
Struts Strange Engineering single-adjustable struts
Springs Strange Engineering coilovers with Hypercoil springs
Camber Plates Steeda Autosports
Brakes Stock
Wheels Billet Specialties Street Lite 15x4
Tires 165R-15
Rear Suspension
Shocks Strange Engineering single adjustables
Springs Stock, 1 coil cut
Control Arms UPR Products Pro-Series with spherical housing bushings
Brakes Stock
Wheels Billet Specialties Street Lite 15x8
Tires Mickey Thompson E/T Street Radial 275-50
RollCage Wild Rides
