Dale Amy
May 10, 2010
Photos By: Tracy Stocker
Engine and Drivetrain
Block FRPP 5.4-liter wet-sump aluminum
Bore Stock
Stroke Stock
Displacement 331 ci
Crankshaft Stock
Rods Carrillo H-beam
Pistons Diamond, to Livernois specs
Compression Ratio 9.3:1
Camshaft Ford GT
Heads Ford GT, Livernois CNC ported
Intake Whipple
Power Adder Whipple 3.4-liter twin-screw supercharger
Throttle Body FRPP Cobra Jet, twin 63.5mm
Mass Air Stock element in JLT cold-air inlet
Injectors 72-lb/hr
Fuel Pump Stock, with Kenne Bell Boost-a-Pump
Headers Kooks 17/8-inch stainless
Exhaust Kooks stainless X-shape crossover; MagnaFlow 3-inch after-cat
Transmission Stock
Clutch Stock
Rearend 8.8 w/3.73 gears; Dynotech one-piece aluminum driveshaft
RollCage Skinny Kid six-point with swing-out door bars
Electronics
Engine Management Stock, with Livernois tune
Ignition Stock
Gauges Stock
Chassis and Suspension
Front Suspension
K-member Stock
Control arms Stock
Springs Eibach springs
Struts Tokico D-spec
Caster/Camber Stock
Brakes Stock Brembo
Wheels Shelby Super Snake
Tires 275/35-R20, Nitto NT555
Rear Suspension
Springs Eibach
Shocks Tokico D-spec shocks
Control arms BMR
Brakes Stock
Tires 305/35-R20, Nitto Drag Radial
