Dale Amy
April 21, 2010
Engine and Drivetrain
Block Stock
Bore Stock
Stroke Stock
Displacement 281 ci
Crankshaft Cobra steel
Rods Oliver
Pistons CP
Compression Ratio 9.0:1
Camshafts Custom turbo grinds
Heads Stock, ported by Boss 330 Racing
Intake Sheetmetal, Hogan's Racing Manifolds
Power Adder Turbo HorsePower twin-turbo kit, modified by Steeda.ca
Throttle Body GT500
Mass Air SCT BA 5000
Injectors 60 lb/hr
Fuel Pump GT500 twin pumps
Headers Custom 3-in downpipe
Exhaust MagnaFlow, 3-in
Transmission Tremec TR-6060 six-speed, Steeda shifter
Clutch SPEC Super Twin
Rearend FRPP 3.27:1 gearset, Moser axles
Electronics
Engine Management Stock, with Steeda.ca tune
Ignition Granatelli coil packs
Gauges Auto Meter
Chassis and Suspension
Front Suspension
K-member Stock
Control arms Stock
Springs Steeda G-Trac
Struts Steeda G-Trac
Caster/Camber Stock
Brakes StopTech 14-in drilled, with four-piston calipers
Wheels ZE Forged, 20x9-in.
Tires Pirelli, 275/35R20
Rear Suspension
Shocks Steeda G-Trac
Control arms Steeda G-Trac
Brakes Stock, with drilled rotors and Hawk pads
Wheels ZE Forged, 20x10-in.
Tires Pirelli, 305/35R20
