Jerry Heasley
March 8, 2010
The last day to enter is July 2, 2010. They will announce the winner on July 4, an appropriate day for the Patriot. Tickets are $3 each or less if you buy in volume. For more information or to buy tickets, go to www.winthemustangs.com.
2010 Patriot Edition Shelby GT500
Engine and Drivetrain
Block Stock 5.4 iron, painted Ford Blue
Crankshaft Forged steel
Rods Cracked forged steel I-beams
Pistons Forged aluminum
Camshafts Dual overhead cam
Power Adder Roots-type supercharger
Cylinder Heads Four-Valve aluminum
Intake Manifold Cast-aluminum with Roots-typesupercharger and air-to-water intercooler
Fuel System Electronic returnless sequential
Exhaust Tuned dual with catalytic converters and X-shape crossover pipe
Transmission Tremec TR-6060 six-speed
Rearend 8.8-inch with 3.55 gears
Electronics
Engine Management Spanish Oak PCM
Ignition Coil-on-plug
Gauges MyColor
Chassis and Suspension
Front Suspension
K-member Stock
Struts Independent MacPherson
Springs Steeda
Brakes Brembo 14-inch diameter vented discs, four-piston aluminum calipers
Wheels 19x9.5-inch forged alumi-num wheels with Patriot center caps
Tires Goodyear P255/40Z-19Rear Suspension
Shocks Twin-tube gas
Springs Steeda Autosports
Brakes 11.8-inch diameter vented discs, two-piston calipers
Wheels 19x9.5-inch forged aluminum wheels with Patriot center caps
Tires Goodyear P285/35ZR-19
