Dale Amy
January 1, 2010
Photos By: Paul Rosner
Engine and Drivetrain
Block Stock
Bore Stock
Stroke Stock
Displacement 302 ci
Crankshaft Stock
Rods Stock
Pistons Stock
Compression Ratio Stock
Camshaft FRPP E303 w/1.7:1 roller rockers
Heads Ported stock
Intake '93 Cobra, polished
Power Adder Powerdyne BD-10 centrifugal supercharger
Throttle Body BBK 70mm
Mass Air Pro-M 75mm
Fuel System FRPP 24-lb/hr, 190-lph fuel pump
Exhaust FRPP 1 5/8-inch ceramic short-tube headers, MAC 2 1/2-inch pipes, w/Flowmaster two-chamber mufflers
Transmission Stock T5
Clutch Stock, original
Rearend 8.8 w/3.55 gearset, Moser 28-spline axles, T/A girdle
Electronics
Engine Management Stock
Ignition MSD Blaster coil
Gauges Saleen white-face gauges and Saleen pillar-mount boost gauge
Chassis and Suspension
Front Suspension K-member Stock
Control arms Stock
Springs FRPP Springs
Struts Monroe struts
Caster/Camber UPR
Brakes Stock, with drilled rotors, Performance Friction pads
Wheels Stock-style, chrome, 16x7
Tires Nitto 450 Extreme, 245/50R16
Rear Suspension
Springs FRPP
Shocks Monroe shocks
Control arms UPR upper and lower
Brakes Disc conversion, Performance Friction pads
Tires Nitto Drag Radial, 245/50R16
