Dale Amy
January 1, 2010
Photos By: Paul Rosner
If you were a Mustang, we're pretty sure you'd want to belong in the stables of a guy like Herman Torluemke Jr. Such ownership would mean you'd be housed in a climate-controlled, pristine 41/2-car garage, shared with a couple other Pony siblings. You'd never have to go to work, and you'd never, ever be asked to navigate through such distasteful and corrosive elements as snow, or even rain. Though you would occasionally be asked to send all 419 rwhp to the pavement, this would be done in such a respectful way that your original clutch and T5 tranny would still be onboard after 17 years. And your polished-to-perfection Oxford White clearcoat finish would be the one applied at the factory back in 1992. Door dings? Never a one. This, in other words, would be the automotive equivalent of being born with a silver spoon in your, uh, grille.
Herman bought this Fox GT new some 17 years ago, after riding shotgun in a buddy's '89 5.0 for a couple years and becoming thoroughly hooked on its "bang for the dollar." But even back then, at the brimming-with-vinegar age of 22, he never abused his new Mustang. Nor did he put it into harness as a daily driver-he had lesser wheels for that chore. The hatchback instead immediately assumed the role of occasionally driven pampered toy, and continues in that role today. At that point it was his sole vice, though a '97 ragtop and an '08 Shelby GT500 have since been added to his personal sin list. "I don't drink; I don't smoke," says Herman, "I'm just addicted to Mustangs."
Looking at the level of detail and polishing underhood, we'd have to say it's a fairly time-consuming addiction, and the chassis is reportedly just as sanitary. Though he's had no problems with the BD-10 centrifugal blower that he installed way back in 1996, Herman had Powerdyne upgrade its internals to stronger BD-11A specs, and now has it pullied for roughly 11 pounds of boost. By careful twisting of the distributor (remember those?) and utilizing a Snow Performance water/methanol injection kit, he hasn't even had to chip the trusty old EEC-IV processor. In fact, because the GT never sees rain, Herman utilizes what used to be its windshield washer bottle as the methanol mix reservoir. If worst comes to worst, we suppose he can always squirt it on the windshield...
Until he added Ford Racing Performance Parts' venerable E303 cam, he ran 3.27 gears in the rearend-they worked just fine with the strong low-end torque attributes of the Powerdyne blower. However, Herman reports that the E303 does its best work with the tach spun a bit higher, so he bumped up to 3.55 cogs to get into the happy range a bit sooner.
Oh, and the "nitrous" bottle in the hatch? No laughing gas is housed within-it simply acts as a disguised subwoofer housing.
Aside from being prized toys, this nostalgic old Fox and his other Mustangs act as pivotal parts of his social life. His buddies seem to gravitate to Herman's place, often completely filling his driveway with their own Mustangs-perhaps no surprise given that his garage is the one with all the cool Ford memorabilia, the huge plasma TV, and the all-important fridge. Said garage's trick new $4,000 floor finish is always spotless. "I'd mop that before I'd mop the kitchen," quips Herman. And what self-respecting car geek could argue with those priorities?
We asked Herman if he had any additional mods planned for his near-historic hatchback. His response: "Well, if I don't blow it up, no, not really." He is, in other words, completely satisfied with the way his fawned-over Fox has turned out, and still loves detailing and driving it every bit as much as his new Shelby. Peaceful is the man who knows when his work of art is complete.
Engine and Drivetrain
Block Stock
Bore Stock
Stroke Stock
Displacement 302 ci
Crankshaft Stock
Rods Stock
Pistons Stock
Compression Ratio Stock
Camshaft FRPP E303 w/1.7:1 roller rockers
Heads Ported stock
Intake '93 Cobra, polished
Power Adder Powerdyne BD-10 centrifugal supercharger
Throttle Body BBK 70mm
Mass Air Pro-M 75mm
Fuel System FRPP 24-lb/hr, 190-lph fuel pump
Exhaust FRPP 1 5/8-inch ceramic short-tube headers, MAC 2 1/2-inch pipes, w/Flowmaster two-chamber mufflers
Transmission Stock T5
Clutch Stock, original
Rearend 8.8 w/3.55 gearset, Moser 28-spline axles, T/A girdle
Engine Management Stock
Ignition MSD Blaster coil
Gauges Saleen white-face gauges and Saleen pillar-mount boost gauge
Chassis and Suspension
Front Suspension K-member Stock
Control arms Stock
Springs FRPP Springs
Struts Monroe struts
Caster/Camber UPR
Brakes Stock, with drilled rotors, Performance Friction pads
Wheels Stock-style, chrome, 16x7
Tires Nitto 450 Extreme, 245/50R16
Rear Suspension
Springs FRPP
Shocks Monroe shocks
Control arms UPR upper and lower
Brakes Disc conversion, Performance Friction pads
Tires Nitto Drag Radial, 245/50R16
