Dale Amy
July 1, 2009
Photos By: Greg Jarem
M5lp_0907_04_z 2007_shelby_gt500_stage_6 Motor
Topped with Whipple's largest screw blower and capable of more than 1,000 flywheel horsepower while operating on its race-fuel tune, Stage 6 No. 014 has a squeaky-clean factory look underhood, thanks in part to its black-powdercoated Moroso coolant and intercooler tanks. This thing is all about deep breathing and precise calibration.
M5lp_0907_06_z 2007_shelby_gt500_stage_6 Stage_6_certificationM5lp_0907_07_z 2007_shelby_gt500_stage_6 Interior
A trio of AutoMeter Nexus gauges are mounted in the stylish individual nacelles of Speed of Sound's A-pillar replacement, along with a Raptor mini shift light. Speed of Sound also makes the three-switch console panel. The pistol-grip is from Hurst, though it commands a Steeda Tri-Ax shifter.
M5lp_0907_08_z 2007_shelby_gt500_stage_6 Evo_performanceM5lp_0907_09_z 2007_shelby_gt500_stage_6 Nitrous_tanks
Bet you're thinking that all this nitrous helped generate the huge power numbers. Wrong. The engine never sees the giggle gas; instead it's used to actuate the ARB Air Locker in the rear axle, which saves having an onboard compressor. Cool idea. Speaking of cool, the spray is also used to rev up bystanders as it purges through the snake in the grille.
M5lp_0907_10_z 2007_shelby_gt500_stage_6 RearM5lp_0907_11_z 2007_shelby_gt500_stage_6 Wheels
Stage 6 exterior mods include the subtle but distinctive step of smoothing and painting the GT500's mirrors, side skirts, and rear diffuser in body color. The KR-style hood and painted stripes on Mike's Torch Red ride are just a couple of Evolution's numerous available options. Standard Stage 6 cabin upgrades include Auto Meter's innovative Nexus fuel-pressure and boost gauges; Mike also opted for a wideband gauge and remote gauge controller. His Speed of Sound console switchplate controls Evolution's line-lock system, and includes a purge button to send red-illuminated nitrous vapor hissing out through the grille-mounted snake emblem, and a third switch to arm the rearend's ARB locking differential, also by way of nitrous instead of compressed air. By the way, Evolution's lead technician, Chuck Wresniewski, gets credit for the trunk's beautifully crafted nitrous hardware and serialization plate. Oh, and we need to point out that the engine itself sees absolutely none of the giggle gas.
To show that it isn't just a haphazard assemblage of random parts, Evolution serializes each of its striking Stage 6 Shelbys, and Mike's is the 14th of the series, having rolled out the door in December 2008. He seems more than pleased with his investment and relishes having what is surely one of the most handsome and fearsome GT500s in the state of Nebraska. As for Evolution, word has it the company is now working on a Stage 7 package, which promises to be just as revolutionary.
Engine And Drivetrain
Block: Stock
Bore: Stock
Stroke: Stock
Displacement: 330ci
Crankshaft: Stock
Rods: Stock
Pistons: Stock
Compression Ratio: Stock
Camshafts: Stock
Heads: Stock
Intake: Stock
Power Adder: Whipple 3.4-liter (W210AX), twin-screw supercharger
Throttle Body: Whipple 160mm mono-blade
Mass Air: C&L air induction system, with DiabloSport MAFia
Injectors: Evolution Performance matched, 72-lb/hr
Fuel Pump: Twin Whipple with Evolution Performance billet fuel rails
Headers: American Racing 1 7/8-inch long-tubes
Exhaust: Borla Touring Cat-Back
Transmission: Stock, with Steeda Tri-Ax shifter and Hurst pistol-grip
Rearend: Currie 9-inch, 3.70 gears, 35-spline axles, ARB Air Locker differential
Electronics
Engine Management: Stock with Evolution Performance tune
Ignition: Stock
Gauges: Auto Meter
Chassis And Suspension
Front Suspension
K-member: Stock
Control arms: Stock
Springs: FRPP
Struts: Tokico
Caster/Camber: Steeda HD upper strut mounts
Brakes: Baer 14-inch, six-piston calipers; FRPP brake-cooling kit
Wheels: Evolution Performance Series 1, 20x9 in
Tires: Nitto 555 Extreme 255/35-R20
Rear Suspension
Springs: FRPP
Shocks: Tokico
Control arms: Evolution Performance upper and lower
Panhard bar: Evolution Performance
Brakes:
Baer 14-inch, drilled and slotted rotor upgrade
Wheels: Evolution Performance Series 1, 20x11 inTires: Nitto 555R Drag Radial, 275/40-R20
