Jerry Heasley
March 1, 2009
Jamey loves the stock interior. He says the Special Vehicle Team worked with Ford's color and trim director to develop the paint and leather. Using a process pioneered by Garden State Tanning of Southfield, Michigan, Mystichrome was applied to the leather inserts of the front and back seats, along with the steering wheel. That's a wild process. "The interior is pretty much stock because I really don't feel the need to upgrade on it, as sick as it is. I just added some extra gauges in the interior for boost, and the wide band air/fuel gauge. When someone walks by the car and raves about the paint, I open the door and show them the interior to really blow their minds."
Finally, at 22 psi, with the spark blowing out, Jamey saw the dyno hit 954 hp at 6,800 rpm and 742 lb-ft of torque at 6,400 rpm. Unfortunately, the dyno tech had to cut the session short, leaving no extra time to pull the Autolite 103 plugs and close the gap from 0.030 to 0.020 inch and achieve the 1,000 hp goal. Jamey blames the spark issue and pig-rich air/fuel ratio for barely missing his 1,000hp target. He views hitting this figure as merely a formality as he tinkers with the street tune.
Engine And Drivetrain
Block
MMR-prepped 5.4 Lincoln Navigator
Bore
Stock 3.55-inch
Stroke
Stock 4.17-inch
Displacement
330ci
Crankshaft
Factory forged Lincoln Navigator crank
Rods
JE forged I-beams
Pistons
JE forged
Compression Ratio
9.7:1
Cams
MMR custom turbo grinds
Cylinder Heads
MMR-ported Lincoln Navigator 32-valve DOHC heads
Intake
Sullivan Performance single-plane intake and throttle-body adapter
Throttle Body
Stock
Mass Air
Ford Lightning 90mm
Power-Adder
THP twin-turbo kit, Precision T-4 67mm turbochargers with 0.68 A/Rs
Fuel System
D'Agostino Racing's MagnaFuel 1,500hp, return-style fuel system; MagnaFuel ProTuner 750 series fuel pump; -10 AN supply and -8 AN return line; Sullivan Performance fuel rails; and Siemens Deka 83-lb/hr, high-impedance injectors w/adapter harnesses
Headers
THP custom headers w/3-in up-pipes
Exhaust
3-in downpipes, 3-in custom X-pipe, and 3-in DynoMax Ultra-Flo mufflers
Transmission
Stock T56 with Liberty 26-spline input shaft and MGW short-throw shifter
Clutch
Spec Super Twin
Rearend
Stock 8.8 IRS w/3.55 gears
Electronics
Engine Management
Stock EEC-V, with Boost Performance DiabloSport tune and DiabloSport MAFia
Ignition
Weapon-X XCOP coils, Autolite 103 spark plugsBoost Controller
Greddy Profec B Spec II
Gauges
Dual-gauge instrument cluster bezel, Dynojet wideband A/F gauge, and Auto Meter NV boost gauge
Chassis And Suspension
Front Suspension
K-Member
QA1
Control Arms
QA1
Springs
QA1 coilovers
Struts
Stock
Caster/Camber
QA1
Brakes
Stock
Wheels
True Forged Victory Series
19x9-in
Tires
Nitto Invo 255/35R19
Rear Suspension
Springs
H&R Sport Springs
Shocks
Stock
Control Arms
Stock
Brakes
Stock
Wheels
19x10.5-in
Tires
Nitto Invo 285/35R19
