Eric English
March 1, 2009
Engine And Drivetrain
Block
Stock 5.0 roller, 0.030-inch over
Displacement
306ci
Crankshaft
Eagle forged 3.00-inch
Rods
Eagle H-beam
Pistons
Probe forged, low-compression
Camshaft
FRPP B303
Cylinder Heads
Twisted Wedge
Rocker Arms
Harland Sharp 1.7 rollers
Intake Manifold
Edelbrock Performer
Throttle Body
Edelbrock 70mm
Power-Adder
Vortech S-Trim
Fuel System
Aeromotive Eliminator system, FRPP 42-lb/hr injectors
Exhaust
BBK 1 5/8-inch short-tube headers, Hedman H-pipe, Flowmaster 40 series
Transmission
Tremec T56 six-speed, King Cobra clutch, B&M Ripper shifter
Rearend
8.8 w/Eaton posi, FRPP 3.73s, FRPP 31-spline axles, FRPP girdle/cover
Electronics
Engine Management
MicroTech ECU, Painless wiring harness
Ignition
MSD 6AL, MSD billet dizzy
Gauges
Auto Meter Phantoms
Chassis And Suspension
Front Suspension
K-Member
QA1 tubular
Control Arms
QA1 tubular
Springs
QA1 coilover
Struts
QA1 coilover
Caster/Camber
Hotchkis
Swaybar
Stock
Brakes
Baer Claw GT, 13-inch rotors, PBR twin-piston PDC caliper
Wheels
MHT Shifter 20x8.5-inch
Tires
BFG KDW 245/35R-20
Rear Suspension
Springs
QA1
Shocks
QA1
Control Arms
Ground Pounder upper and lower
Swaybar
Stock
Brakes
Baer Claw Sport, 12-inch rotors, PBR single-piston caliper
Wheels
MHT Shifter 20x9.5-I
Tires
BFG KDW 285/30R-20
Chassis Stiffening
Custom rollcage by Wade Halbert
