Dale Amy
January 1, 2009
Brakes and rolling stock also received upgrades over the winter, with Baer Extreme-Plus 14-inch-rotor/six-piston brakes now tucked behind gorgeous (and pricey) three-piece HRE C21 rims, measuring 20x9.5 in front and 10.5-inch-wide out back. In a search for traction, Nitto's new 305/35R20 drag radials were mounted, and when the weather permitted, Rick once again made the trek to Milan. To his pleasant surprise, the 20-inch Nitto's hooked so well that the car bogged on launch and produced 1.69-second 60-foot times. The first few passes were all low 11s at 124-125 mph, then Rick let the GT cool briefly before ripping off a 10.82-second blast at 126 mph-thereby meeting the goals for the project.
We'll let Rick summarize: "I drive the car quite often through the week, and race or show it on weekends. [These times are] not bad for a car that you can drive to or from the track, or on a long trip with the windows up and the air on. We plan to see what else we can get out of it. The next modification will be a smaller pulley, then who knows..."
The cloth interior is pretty much stock, save for a Pioneer AVIC-Z2 combined GPS and head unit, backed up by Kenwood Excelon speakers. The control unit for an Alky Control progressive methanol injection system is tucked in the glove box. Beneath that ungainly factory shifter is an utterly stock (save for programming) 5R55 automatic transmission and torque converter happily running 10-second quarter-mile times and serving seamless street duty.
ENGINE AND DRIVETRAINConverter
BlockStock
StockRearend
Bore3.73:1 gearset; stock axles and
3.555-inchdifferential
Stroke
3.750-inchELECTRONICS
DisplacementEngine Management
298ciStock, with Dan Millen tune
CrankshaftIgnition
Livernois forged-steel strokerStock
RodsGauges
Livernois/ManleyStock
Pistons
Livernois/MahleSUSPENSION AND CHASSIS
Compression RatioFront Suspension
9.1:1K-member
CamshaftsStock
StockControl Arms
HeadsStock
Livernois Stage 3 portedStruts
IntakeFRPP Handling Pack
WhippleSprings
Power AdderFRPP Handling Pack
Whipple H.O. twin-screwCaster/Camber
intercooled superchargerStock
Throttle BodyBrakes
Whipple 1750-cfm billetBaer Extreme-Plus with six-piston
Mass Airmonoblock calipers
WhippleWheels
InjectorsHRE C21 Competition, 20x9.5
52-lb/hrTires
Fuel PumpPirelli P-Zero, 275/35R20
Livernois custom dual-pumpRear Suspension
HeadersSprings
Kooks long-tube, 1 3/4-inchFRPP Handling Pack
primaries, 3-inch collectorsShocks
ExhaustFRPP Handling Pack
Kooks off-road crossover;Control Arms
MagnaFlow 3-inch exhaustStock
Transmission
Stock 5R55
