Michael Johnson
January 1, 2009
Photos By: Dale Amy
To make the 700-plus horsepower the Williams' coupe is capable of, it helps to have a sturdy base. Cody chose a Dart block with a 4.125-inch bore and an Eagle 3.47-inch stroker crankshaft to arrive at 363 ci of Ford muscle. Swinging from the Eagle crank is a set of that same company's connecting rods attached to eight JE pistons wrapped in Hellfire rings. AFR 205 heads, which were ported "a little," according to Cody, play host to Comp Cams Pro Magnum 1.6 roller rockers. A Coast High Performance EFI Spyder intake adds an exotic twist to the mix. Many Mustangs wouldn't need such a piece, but with a Precision Turbo single PT88 turbocharger huffing out 20 pounds of boost, it's a good idea to have one. To tune the crazy combination, Coddy and Deanna utilize an ACCEL Gen 7 standalone system.
Ah, the prized black interior. Cody has accented his with a Nosnhoj Enterprises rollcage and other necessary safety equipment, such as G-Force harnesses and a window net. "It has all of its stock interior," Cody says. An Innovate Motorsports wideband keeps tabs on air/fuel, while Cody works the B&M Performance Products Hammer shifter. Other mechanical measurements are monitored courtesy of Auto Meter gauges.
ENGINE AND DRIVETRAINMotorsport PMS
BlockIgnition
Dart, 4.125-inch boreMSD w/ Blaster coil, Ford Racing
Rotating AssemblyPerformance Parts spark plug
Eagle 3.47-inch strokerwires, Autolite spark plugs
crankshaft and connecting rods,Gauges
JE pistons, Hellfire piston ringsAuto Meter
Displacement
363ciSUSPENSION AND CHASSIS
CamshaftFront Suspension
Comp CamsK-member
HeadsQA-1 tubular
AFR 205, Comp Cams ProControl Arms
Magnum 1.6 roller rockersQA-1 tubular
IntakeSprings
Coast High Performance EFIQA-1 coilover
SpyderStruts
Throttle BodyQA-1 coilover
75mmCaster/Camber
Mass Air MeterQA-1
Pro-MBrakes
Power AdderAerospace Components
Precision single PT88Wheels
turbocharger, air-to-airCenter Line Convo Pro
intercooler, 20 pounds of boostTires
Fuel System165R15
Aeromotive A1000 fuel pump,Rear Suspension
regulator, and fuel rails; customSprings
lines, MSD 96-lb/hr injectorsStock
ExhaustShocks
BNG turbo headers, customLakewood 50/50
Nosnhoj Enterprises H-pipe,Traction Devices
Flowmaster mufflersSouthside Machine double-
Transmissionadjustable control arms
Performance Automatic C4,Brakes
B&M Performance ProductsAerospace Components
3,500-rpm stall converter andWheels
Hammer shifterCenter Line Convo Pro
RearendTires
8.8, 3.55 gears, StrangeMickey Thompson ET Street
Engineering spool and 33-splineradials
axlesChassis Stiffening
ELECTRONICSand subframe connectors
Engine Management
Stock computer, Anderson Ford
