November 1, 2008
ENGINE AND DRIVETRAINELECTRONICS
BlockEngine Management
Stock 5.0, Bored 0.030-InStock A9L Computer
Rotating AssemblyIgnition
{{{Eagle}}} Stroker Crankshaft AndMsd 6AL w/ Blaster Coil, Taylor
I-Beam Connecting Rods, JEThundervolt Spark Plug Wires,
Forged Pistons, Total SealNGK Spark Plugs
Piston RingsGauges
DisplacementAuto Meter
347ci
CamshaftSUSPENSION AND CHASSIS
Comp Cams Extreme EnergyFront Suspension
282H, FRPP LiftersK-member
HeadsProfab Tubular
AFR 185, 2.02/1.60 Valves,Springs
Crane Roller Rockers, CompQA-1
Cams ValvespringsStruts
IntakeStrange Engineering 10-Way
Edelbrock Performer RPM IIAdjustable
Throttle BodyCaster/Camber
Professional Products 75mmSteeda Autosports
Mass Air MeterBrakes
Pro-{{{M}}} 76mm, Anderson {{{Ford}}}Stock Disc, Hawk Brake Pads
Motorsport Power Pipe, K&NWheels
FilterWeld Racing Pro Stars 15x3-in
Fuel SystemTires
Walbro 255-Lph In-Tank FuelRepublic 165R15
Pump, Stock Fuel Lines AndRear Suspension
Rails, FRPP 30-lb/hr Injectors,Springs
Aeromotive Adjustable Fuel-Stock
Pressure RegulatorShocks
ExhaustLakewood 50/50
BBK 1 3/4-Inch Long-TubeTraction Devices
Headers w/ Corresponding X-UPR Products Adjustable Upper
Shape Crossover Pipe,And Lower Control Arms And
Flowmaster One-ChamberAntiroll Bar
Mufflers w/ DumpsBrakes
TransmissionDisc, Hawk Brake Pads
T5, Spec Stage 3 Clutch AndWheels
Pressure Plate, Pro-5.0 Shifter,Weld Racing Pro Stars
FRPP Aluminum DriveshaftTires
RearendMickey Thompson ET Street
8.8, 4.30 Gears, StrangeRadials 275/60
Engineering Spool And 33-Chassis Stiffening
Spline AxlesHP Motorsport Weld-In Subframe
 Connectors
