Michael Johnson
October 1, 2008
With the desire to simply drop in an engine, Mark purchased a D.S.S. Racing Super Pro Bullet 306 with Trick Flow Track Heat heads and a turbo-grind camshaft. Hogan sheetmetal adds pizzazz and power underhood thanks to a Holley 75mm throttle body. For boost, Mark chose an HP Performance single-turbo kit using a 60mm turbo and air-to-air intercooler. Willie Figueroa tuned the car using DiabloSport software. To keep things cool on the street, Mark added a Fluidyne aluminum radiator and a Meziere electric water pump.
ENGINE AND DRIVETRAINaxles w/ C-clip eliminators, TA
Blockrearend girdle, 3.55 gears
Stock, 0.030-in overbore
Rotating AssemblyELECTRONICS
D.S.S. Racing Super Pro BulletEngine Management
short-block w/ windage tray andStock A9L computer, DiabloSport
main girdle, Fluidampr harmonictune
damper, Canton Racing oil panIgnition
DisplacementMSD 6AL w/ two-step in-line w/
306citransbrake, ACCEL coil, Moroso
Camshaftspark plug wires, NGK spark plugs
Comp Cams turbo grindGauges
HeadsAuto Meter, cowl gauge panel
Trick Flow Track Heat, 2.02/1.60
valves, Comp Cams Pro {{{Magnum}}}SUSPENSION AND CHASSIS
roller rockers, ARP hardware,Front Suspension
custom valve covers w/ weldedK-member
AN bungs for oil evacuationUPR Products tubular w/ tubular
IntakeA-arms
Hogan sheetmetal, 1-in phenolicSprings
spacerUPR Products coilover
Throttle BodyStruts
Holley 75mmLakewood {{{90}}}/10
Mass Air MeterCaster/Camber
C&L 76mmUPR Products
Power AdderBrakes
HP Performance Stage 1 single-Aerospace Components disc
turbo system and air-to-airWheels
intercooler, Holset 60mmWeld Racing Magnum 2.0
turbocharger, 9 pounds of boost,15x3 1/2-in
Tial 44mm wastegate, TurboTires
{{{Smart}}} blow-off valveMetric 165R/15
Fuel SystemRear Suspension
Glenn's Performance sumped fuelSprings
tank, Twin Bosch {{{300}}}-lph fuelEibach Drag Launch w/ airbag in
pumps, pushlock lines fromright rear
firewall back, braided lines inShocks
engine compartment, AeromotiveLakewood 50/50
fuel rails and regulator, Lucas fuelTraction Devices
injectorsSouthside Machine lift bars, UPR
ExhaustProducts upper control arms
HP Performance turbo headersBrakes
w/ 1 3/4-inch primaries, DynoMaxStock
Race Bullet mufflersWheels
TransmissionWeld Racing Magnum 2.0
Michael Boatwright-built C4, PTC15x9 1/4-in
3,500-stall converter, reverse-Tires
manual valvebody w/ transbrake,Mickey Thompson ET Street
B&{{{M}}} Performance Products pan,radials 275/60
FRPP aluminum driveshaft,Chassis Stiffening
Lakewood driveshaft loop, Hurst{{{Eight}}}-point rollcage and subframe
Quarter Stick shifter w/ pistol gripconnectors
Rearend
8.8, Moser spool and 33-spline
