Dale Amy
May 1, 2008
Clearly opting for the sheep's-clothing look, Maury mounted unpretentious Pony rims and added a GT spoiler and Cobra grille. Only the observant might notice the custom lower duct for the intercooler. Everything else is original and designed to lull the unsuspecting into a turbo trap. Or maybe just keep Maury out of jail.
Horse Sense: Maury's LX hatchback came with the optional GT high-back buckets. Sadly, these weren't available in the notchback. I lamented this fact when I ordered my own '89 LX notch.
A properly engineered turbo setup huffing into a Ford small-block is a wondrous thing. It provides all the boost anyone would ever want without parasitic drag, while acting as an effective upstream muffler to keep things discreet-or sneaky, depending on the intended mission profile. As a trackside photographer still in possession of some hearing, I've come to appreciate the near-silent launches of turbo drag 'Stangs. After riding shotgun in Maury Moynihan's oh-so-discreet '89 LX-with not just one, but a pair of horsepower hair dryers onboard-we're happy to report that his self-engineered setup not only hits with all the force of Thor's own hammer, but it's also well-mannered while stalking the pavement of southern Ontario in the role of Maury's daily summer driver.
The turbos are a pair of Garret T3 60/63s, with Turbonetics Evolution wastegates, a Turbo XS boost controller set at 10 psi, and Bosch blow-off valves. Fitment required a custom radiator saddle and a lot of custom duct fabrication-all crafted by Maury Moynihan in his home garage. Yes, Canadian winters are long.
Maury bought the Dark Shadow Blue hatchback new when he was a mere 18 years old. Like any good gearhead, he has since put it through many permutations of displacement and power adders, yet has steadfastly maintained its innocent outward appearance. Apparently, it's not innocent enough, as testosterone-induced early antics in the LX cost him a four-year license suspension. While those days of road-going insanity are now firmly behind him (we think), Maury is still obsessed with horsepower and good ol' torque. They're both available at the mere nudge of the throttle on his stoutly underpinned 306 ci engine, that is, of course, effectively expanded to much greater displacement by the hulking turbo duet.
Let's talk about those turbos and what it took to persuade them-along with a custom intercooler and its associated plumbing-to peacefully cohabitate with the bored and beefy small-block in the limited confines of a Fox engine bay. In brief, this exercise took: 1) Maury, 2) his small home garage, and 3) a lot of time and patience. He did all the duct/exhaust fabrication in support of the pair of Garrett T3 60/63s himself.
The understated, near-stock theme carries on indoors, though Maury has filled the ashtray with functional, illuminated switches and populated the center stack with Auto Meter Phantom gauges and a remote-controlled Sony head unit. The door panels sport MB Quart drivers. There's also a neat little-and we mean little-shift light tucked discreetly beneath the dashpad, centered over the instrument cluster.
To keep things cool, he fitted a pair of 12-inch blow-through electric fans-one of the few blow-through setups we've ever seen on a Mustang-on a Ford Racing Performance Parts aluminum radiator, mounted on a slight angle to a custom, relocated rad support in order to make everything fit. On another aspect of keeping the cool, the turbo piping is all thoroughly heat wrapped.
To deal with the resulting 579 hp and 658 lb-ft of torque at the wheels (recorded on a conservative Mustang dyno), the stock block was rebuilt with D.S.S. 8.8:1 pistons with valve reliefs for the Trick Flow Twisted Wedge heads. The rods are stock, but they're secured with ARP Wave-Loc fasteners. The cam is also stock, but it operates through Trick Flow 1.7:1 roller rockers. The old T5 is long gone, replaced by a D&D Performance T56 six-speed, feeding a rearend upgraded with Moser axles and carbon-fiber clutch packs in the otherwise stock Traction-Lok diff.
Resulting from Mega-Bite Jrs., Wild Rides torque-box reinforcements, boxed upper control arms, and an airbag in the right rear spring are 1.79-second 60-foot times. Though drag racing is low on its priority list, Maury's daily commuter has run 11.04 seconds at 129.2 mph, and that trap speed gives good indication of the little 306's Hoover Dam power output.
A JL subwoofer dominates the floor of the hatch area, and Maury crafted a compartment for the passenger side that houses not only a CD changer, a Phoenix Gold amp, an Optima battery, and a custom 7-liter stainless tank for the water/methanol injection system. Its plastic cap can be seen through the carpeting.
Since this is a daily driver-we keep mentioning that, don't we?-Maury paid attention to other critical areas such as an upgraded four-wheel disc-brake setup and a kick-butt sound system, some of which shares hatch room with the car's stainless steel, water/methanol injection storage tank. In other words, he sweated the details and continues to do so every winter once the car comes off the road.
In any event, Maury's impressive exercise was clearly worth the effort, as the end result is a quiet and tractable commuter. The car, with its current 3.27 gears (Maury is thinking of dropping to 3.08s), has the wonderful combination of reliable driveability and berserk throttle response that can break the sticky Nitto Drag Radials loose virtually at will, quite likely in every gear. Afterward, a pair of black tire tracks and the sound of excess boost purging through the Bosch blow-off valves are the only clues that something politically incorrect has been committed. That, and the smile on the author's face.
BlockCustom aluminum
Bore8.8, Moser axles, aluminum
4.03girdle, 3.27 gears
3Traction-Lok w/ carbon-fiber
Displacementclutch packs
Stock, heat treatedEngine Management
Stock, w/ ARP Wave-LocIgnition
fastenersMSD 6AL-BTM, Jacobs Ultra
Compression RatioAuto Meter
StockFront Suspension
Rocker ArmsK-member
Trick Flow 1.7:1Stock
Power AdderControl Arms
Twin Garret T3 60/63Stock
Custom 8x22x3-inFRPP 'C'
Boost CoolerStruts
Custom methanol/waterStock
Trick Flow, O-ringedBrakes
IntakeSVO calipers, braided lines, '96
Edelbrock Performer{{{GT}}} master cylinder
Throttle BodyWheels
70mmStock Pony
Mass AirTires
Pro-{{{M}}} 3-in blow-throughBridgestone Potenza
InjectorsRear Suspension
Fuel PumpFRPP 'C'
255-lph w/Kirban regulatorShocks
Custom; same w/ all turboControl Arms
ductingBoxed upper/Mega-Bite Jr.
Dr. Gas X-shape crossover w/11.25-in. cross-drilled rotors,
cats, DynoMax Super turboSVO calipers, braided lines
TransmissionStock Pony
D&D T56Tires
ClutchNitto Drag Radial
SPEC aluminum flywheel, Stage
3+ clutch
