Dale Amy
April 1, 2008
Speaking of investment, James added more in the cabin and hatch areas. The HVAC controls sit lower than usual in the center stack, which was necessary to custom-mount a 7-inch LCD monitor above, while a flip-down Pioneer head unit resides beneath. Less obvious are the suede headliner, visors, and door inserts, but more apparent are the twin 10-pound nitrous bottles nestled in the custom rear-seat delete, where James' proud dedication to the Saleen brand are equally apparent. Oh, and the trunk is now useless-at least for its originally intended purpose-thanks to the custom-mounted, 10-inch Infinity subs book-ending the 1000W Power Acoustik amp on the trunk floor.
As you've by now likely surmised, this stylized Saleen no longer serves daily driver duty. It now sees only occasional sunny-day cruises and plenty of car shows. By the way, James is now 24. I can't help but wonder what automotive creations he will concoct by the time he reaches my grizzled, old age.
ENGINE AND DRIVETRAINFlywheel
BlockSPEC
Stock cast-ironRearend
BoreStock, 3.55:1 gearset
3.572
StrokeELECTRONICS
StockEngine Management
DisplacementStock w/ SCT tune
283ciIgnition
CrankshaftStock
Cobra forgedGauges
RodsAuto Meter
Manley H-beam, forged
PistonsSUSPENSION AND CHASSIS
Diamond forgedFront Suspension
Compression RatioK-member
9.1:1Stock
CamshaftsControl Arms
Modular PowerhouseStock
customSprings
HeadsSaleen Racecraft
Revalved stockStruts
IntakeSaleen Racecraft
StockCaster/Camber Plates
Power AddersStock
Saleen/Eaton RootsBrakes
supercharger, intercooledSaleen/Brembo, 13-in
with custom {{{NX}}} nitrousWheels
Throttle BodyZenetti Stella, chromed
FRPP 75mmTires
Mass AirYokohama, 265/35R18
SCT BA2400Rear Suspension
InjectorsSprings
60-lb/hrSaleen Racecraft
Fuel PumpShocks
Twin Cobra in Cobra tankSaleen Racecraft
HeadersControl Arms
BBK long-tube, ceramic-Stock
coatedBrakes
ExhaustStock
BBK H-pipe, Saleen/BorlaWheels
mufflersZenetti Stella, chromed
TransmissionTires
Built Tremec 3650BFGoodrich Drag Radial,
Clutch295/35R18
SPEC
