July 19, 2007
Photos By: Dale Amy
Wayne Kutchyn of HeadWinds in Westland, Michigan, built Jason's 306 using a '93 5.0 roller block, a stock crankshaft, Eagle rods, and JE pistons. Wayne added a Cam Motion solid-roller cam and lifters, Edelbrock Victor Jr. heads and intake, and a Barry Grant Demon 650-cfm carburetor. With a C4 behind the 306, the combination is good for 11.60s and 340 rwhp.
You don't see many early Fox Mustangs featuring aftermarket seats, but Jason added Corbeau TRS seats to the mix, along with several Auto Meter gauges to replace the factory units. The stock '82 gauge panel remains, but Jason transplanted Auto Meter gauges in place of the stockers. A Florida 5.0 gauge pod plays host to other Auto Meter offerings. To keep the 306 from coming apart, Jason utilizes an MSD lean/rich indicator to keep an eye on the air/fuel ratio.
5.0 TECH SPECS
ENGINE AND DRIVETRAINELECTRONICS
BlockIgnition
'93 5.0 rollerMSD 6AL, NGK spark plugs
DisplacementGauges
306ciAuto Meter, Florida 5.0
Rotating Assemblygauge pod
Stock crankshaft, Eagle I-beam
connecting rods, JE pistonsSUSPENSION AND CHASSIS
and ringsFront suspension
Cylinder HeadsK-member
Edelbrock Victor Jr., Ferrea Stock
2.05/1.60 valves, FRPP 1.6A-arms
roller rockers, Comp CamsStock
valvespringsSprings
CamshaftFRPP
Cam Motion solid-rollerStruts
Intake ManifoldLakewood 70/30
Edebrock Victor Jr.Wheels
CarburetorWeld Racing Draglite 15x3 1/2-in
650-cfm Barry Grant DemonTires
Power Adder165R15
Jason's right footBrakes
ExhaustStock
BBK 1 3/4-in long-tube headers,Rear Suspension
Dr. Gas X-shape crossover,Springs
Flowmaster two-chamber mufflersFRPP
Fuel SystemShocks
Holley Blue fuel pump, AeromotiveLakewood 50/50
{{{100}}}-micron fuel filter, Glenn'sControl Arms
Performance braided fuel lines,Southside Machine lowers, UPR
Holley fuel pressure regulatorProducts double-adjustable uppers
TransmissionWheels
C4, reverse-manual valve-body,Weld Racing Draglite 15x7-in
Dynamic Racing Transmissions/TCTTires
3,800-stall converter, B&{{{M}}} HammerMickey Thompson E/T Street
shifter, FRPP aluminumRadial 275/50
driveshaftBrakes
RearendStock
8.8, 4.30 gears, EatonChassis Stiffening
differential, Moser 31-splineTubular subframe connectors,
axles, TA rearend girdlereinforced torque boxes
